48" dual fuel burners clicking wont stop after lit.
48" monogram dual fuel propane burners when lighting the ignitor continues to click and not go off on four of the six. Until today it was only two burners. it is 1-1/2 years old. How do I fix?
The wiring harness for the burners sound like is shot! I would think about buying a new one! have You tried to light the burners with a lighter or match to see if they will ignite? If so,replace the wiring harness, over time they go bad and short out! If You Can use lighter to ignite burner I would use the long nosed ones like You start charcoal with till The new wiring harness arrives! You will save the hair on Your arm that way! LOL! Good Luck!
If you are saying the clicking continues you must move the burner knob past the LITE position. If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
