Question about Necchi 6015 Mechanical Sewing Machine
How to put bobbin in for a necchi omega
Not putting the bobbin in correctly
SOURCE:
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
Australian S
  • 46 Answers
SOURCE: I just replaced the belts on my Necchi 535FA, but
If the belts are not tight enough they will slip, they should all be fairly tight but not like a piano string if you know what I mean.
As you do not describe what the machine is doing wrong I can not really say any more at present, except make sure there is no oil on the belts and the machine has no tight spots when you turn it over by hand.
Posted on Jul 07, 2009
miket756
  • 2702 Answers
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
  • 96 Answers
SOURCE: Manual for New Home Special Edition Necchi 6015
google manufacturer and email request
Posted on Dec 13, 2009
  • 1116 Answers
SOURCE: necchi sewing 6030 machine manual
This is the only offering I could find - http://www.sewingstyle.com/necchi-6030.html
Posted on Apr 13, 2010
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
Necchi sewing maching adjustments
try a new needle
rethread the machine top and bobbin
try adjusting the top thread tension
make sure the bobbin is inserted into the bobbin case correctly
Mar 23, 2015 | Necchi Sewing Machines
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
Stuck bobbin
Please put on the bobbin correct size. And check the tension . Then use new threads.
Dec 19, 2013 | Necchi Sewing Machines
Necchi 537l
Sometimes the cotton is too loose on the bobbin; check this first then try putting the bobbin in again making sure you have threaded it in correctly, hope this helps
Jul 31, 2013 | Sewing Machines
My bobbin thread on My Necchi 681c keeps on jumping out of the slot, how can I stop this?
there are several possibility's
1.is the bobbin warped
2.is the bobbin case damaged
3.is the bobbin the right one for the machine
4.is the bobbin wound correctly & inserted correctly into the machine
Mar 26, 2012 | Necchi Sewing Machines
I have an Necchi and omega sewing machine the model is 6022. I need a bobbin case that holds the bobbin in it and the owners manuel can you tell me the price of each one of them
Go to http://allynint.com/
Get the phone number off the web and call them, they have what you need.
If you speak to Dorothy, or Bob Coen, tell them Merry Christmas from Ellen in Arizona. Merry Christmas to you too,
Dec 24, 2010 | Necchi 6015 Mechanical Sewing Machine
How do you change the bulb in the necchi omega 6018
there is a door on the left it's called a lamp cover door or a face plate- on my mechanical necchi there are hinges behind the door at the back,,gently pull open the door & the bulb will be accessible
on my other necchi there is a cap in the middle of the door with a hidden screw, gently pry the cap out & take out the screw & there is the bulb,,just reverse the process to put the door back on
Dec 08, 2010 | Necchi 6018 Mechanical Sewing Machine
How do i thread the bobbin on my necchi 539
take out your bobbin and turn it the other way
Feb 02, 2009 | Necchi Sewing Machines
Necchi 6015 Mechanical Sewing Machine Logo
46 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
