HP W2007 LCD Monitor Logo
A
Anonymous Posted on Nov 12, 2013
How to disassemble w2007 monitor - HP W2007 LCD Monitor
1 Related Answer
Bay Ridge
Bay Ridge
  • 102 Answers
  • Posted on Sep 16, 2009
SOURCE: HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
My hp w2007 turned blue after I moved it how do I access screen display from the monitor menu
Some monitors change colour if there is damage, internally, within the signal cable. Try another cable if you have one.
Alternatively, it might be that the monitor is near an extremely strong magnetic source, such as big loudspeakers?
I have a Hp 500 (OLD) and a hp w2007 monitor that says' no signal? I have checked chords is the problem the monitor or my old tower
If both monitors give no signal, the computer has a video graphics card issue or a motherboard problem, now when you checked the video cord, do you change it? if you have a extra cord, sub it to be sure.
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
1helpful
My monitor (HP w2007) presents a screen when it is powered on but the display only remains on for about 1 second before turning off. I disassembled the monitor to examine the power supply board and fuse...
Yes, the likely cause is the power supply/inverter board, in most cases it is bad capacitors and solder connections. If any capacitors are puffed or show a slight dome shape at the top, chances are it is open.
How is the housing around the HP w2007 opened to work on/ repair internal parts? I don't want to damage or break anything experimenting. Thanks!
matt5883, Since there are thousands of units that need work done on them, I'll just bet that you will find a video clip at YOUTUBE that will be worth a thousand words!!! Once you get to YOUTUBE do search (query) for "lcd monitor disassembly" and also "lcd monitor repair" You will truly be amazed at what you can find on the web these days!!! 12fixlouie
Does my HP w2007 have a mircophone
i am pretty sure it doesnt, sorry, most lcd mointers that arnt t.v.s usally dont have built in speakers or a mic, if it does it would have a 3.5 mm port or plug somewhere
2answers
No sound on the hp w2007
Those speakers require a certain cable connected to the computer aside from the monitor's own cable.
My hp w2007 monitor has no sound.
my hp w2007 monitor has no sound
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
