Sheffield stages crib model#04510-249
SOURCE: conversion instructions from crib to full size bed
check this website. www.babysdream.com/Service/AssembIns/pdf/Convertible%20Generation%20Next%20Crib%20Instruction I needed the instruction to convert my daughters bed and was looking for some help and notice your question.
Good Luck
SOURCE: crib hardware
Thank you to the Grandma J who pointed out the Jenny Lind is a style, not a company! I have two different Jenny Lind cribs and I found the phone numbers for parts right on the crib, on the mattress support for both cribs, with each company. Just remove the mattress and your information should be there!!!
SOURCE: Need just the hardware for Vicki crib/toddler bed
go to www.sorellefurniture.com or you can order it from where you got the crib, or baby depot can get it for you, just tell them that is where you got the bed from.
SOURCE: I need crib hardware for a LUV Delta 5 in 1 crib
I need hardware as well. I called Delta Childrens Product Customer Service and they charge $35.00 for the hardware for my Luv 5 in 1 Crib (model 4822). I tried several hardware stores and none of the bolts I purchased fit. According to Delta, since the crib was made in Indonesia, the hardware has to come from that country.
SOURCE: converting crib to full size bed
I just finally got my full bed put together and it was really easy and looks great! Ok so I called Jardine enterprises and they told me to call Sleepy's and ask for a Universal hook-on metal rails for a crib. So I did that and the Sleepy's I called said they were discontinued. I continued to call several more Sleepys till I got someone who told me that they were indeed available and he knew exactly what I needed...he just converted his 3 year old's bed. He was right and everything worked out perfectly. The gentleman I spoke with at Sleepy's is Damien. Your best bet is to call him no matter where you are located and he will order you exactly what you need or tell you which location to pick them up from. He is in a Sleepys in NJ #201-487-4242. They can deliver it to you and I think the charge is $90...well thats atleast what mine was but they also delivered a full box which I HIGHLY RECOMMEND because the bedrails make the bed really low to the ground and it does not look good that way. I have the manual for converting the kit if you decide to do it on your own. If you need it just respond to this answer. One more thing that I did not realize when the bed rails came and I thought they were not what we needed. You need to follow the instruction manual because it is very important that you take your crib apart completely to get both headboard
