SOURCE: tv always turn off
Here this coveres all the error codes.
Pressing the front panel "INPUT" and "MENU" buttons at the same time,
and holding for 5 seconds,activates the Error Code Mode. The LED
flashes denoting a two digit Error Code, or indicating no problem has
occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
1â• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
2â• The flashing then pauses for approximately 1/2 second.
3â• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
4â• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occured.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
If you find this helpful please accept this solution and let me know if you need any further assistance.
Thanks,
Lee
SOURCE: GREEN LIGHT BLINKING AND TELEVISON WILL NOT RESET ON MITSUBISHI WS-48613
Bad solder on the vertical ic401, or bad solder on the yoke.
SOURCE: Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
SOURCE: mitsubishi tv ws-55311
Mine did the same thing. It was too much money to invest in old technology. I chucked that baby to the curb and got a 42" LCD. LOVE IT!!
SOURCE: mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Testimonial: "this is a neat site...and quick with the responses..will use again"
