I bought a B60, brought it home and it made great coffee. I used both k-cups and the "make your own" filter. I was away for 3 weeks and the coffee maker wouldn't make but about 3 ounces. so I took it back to the store. I had only owned it for less than 90 days. Now I have a brand new one and the coffee tastes terrible. I have tried both k cups and my own coffee. It's really weird. Thanks for your help.
SOURCE: Coffee doesn't taste good
even if the machine is new use a decalfier 1 partsolution 1 part water normally when you clean start the machine turn it off for a few minute repeat until emty rinse it very good thatstuff is very corosif try after a good wash and dont forget it like a the pot the older the better hope it work cheers
SOURCE: Plastic Smell & Taste
take up smoking
and then you will loose you smell and taste.
every thing is made of plastic and aluminum now.
only a stainless pot does not leach plastic cfc into water when hot.
SOURCE: watery tasting coffee
Have you tried cleaning it with the 64 ounces of white vinegar?
Read your booklet if you still have it. Pour the vinegar in run it through until it ask for more water to be added and just let it sit overnight or at least 8 hours. Then flush it out with fresh water at least two or three of your water tanks should do it. Then give it a try again.
Just a suggestion if you haven't tried that yet. Hope it helps.
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
Just bought this for my husband. I found the coffee to have a funny smell and taste. If any one can figure this out that would be great. In my opinion I believe it has to do with the rubber tubing. Here is why I think that to be the case. We go camping and my husband sets up a special hose (the white hose) for running water into the trailer. The first time we set up I made coffee in my regular pot (didn't own the Keurig yet) and it had the same odd taste and smell as what I am now getting from the Keurig. At first I thought it was the campgrounds water so I made the coffee with bottled water that I brought. Then we went on to a different campground and the same thing happened. I believe the hose that the water runs through is what gives me the bad taste in my camper and I believe the rubber tubing the water flows through in the Keurig is the cause of the bad smell and taste. My kids even made hot cocoa and could not drink it. Their response "it tastes like camp water." I am pretty sure its the hose/tubing.
