Think this explains it, had direct tv, now need to program Cox Cable?
Go to www.remotecodelis.com or memorex.com
God bless you
SOURCE: how do i change the settings on the lcd screen and how do i program my direct tv?
Here is the link to the owners manual: http://www.universalremote.com/resources/pdfs/MX-850OwnerManual.pdf
SOURCE: "Select" button doesn't work-Cox universal remote for XBOX 360
Depending on the specific remote, some buttons may not work with all systems. HOWEVER, in many cases the things you thing the "select button" would do, are done by the "play button" instead (IE: That's how I have to select DVD menu options with my remote).
If that is not the case with you, you can try a different programing code.
Testimonial: "I tried that it didn't work. And I tried the programming codes that I found online for the exact same problem but a comcast remote instead of cox."
SOURCE: Do I need a cable box to make it work on my tv?
Only if you have satellite otherwise if you have cable service you should be able to get basic channels by plugging cable direct into tv if that outlet is active.
Good Luck..
SOURCE: Ihave an Aeros MX850 remote that was programmed
All you need to do is make a small programming change. Go to www.totalcontrolremotes.com and click the contact us link and explain the problem. You will get immediate assistance and they program all URC remotes.
Good luck,
Jimmy
SOURCE: I had to get a new TV HD receiver. How do I get it
What kind of receiver did you get? DirecTV, Dish, or something else? This remote comes with software and cables you can connect to your computer. Once you install it, and connect the device, you can program it to connect with your specific electronic components. You may need your existing/original remotes to help get everything set up, but usually that is a one-time process.
