ERROR 2:
Appears if the number of parameters differs from the permissible number.
You can download the EasyCut Pro software from https://www.easycutpro.com/ and give it a try.
This vinyl cutting software works great with Roland GX-300 CAMM-1 Pro Vinyl Cutter.
Yes, if you have a photo editing program, like googles free Picassa. You can change the text all kinds of ways from the basics to the shadow directions. There are all sorts of fonts and colors, look in your programs, the chances are that you have a photo editing program. Most of them if not all, have the features to allow experimenting. I just did a similar thing on an old document where I scrolled until finding the almost perfect text, and then was able to fade it and change the shape and texture to look like the original text. Good luck
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
look on www.rolanddg.co.uk and they might just help. i have just got a pc60 and the test print/cut is'nt working so i'm not a happy bunney. Andy @ YesIDoOwnTheRoad.com
