Curios, why did you order another control panel? I need some history, when it worked, how it failed, any other information like if it was moved or rewired for power...etc.
Testimonial: "Thank you for your response."
I purchased this hot tub used from a friend who told me that everything was in good working order except the topside control panel. I called and ordered a panel for the model tub that I have and received this controller in the mail. The control panel I received appears to be for a tub with 1 pump and 1 blower. I have 2 pumps and no blower so that is why I am curious if this is the right panel. looking on line I see there are 2 panels with the same number. 1 has 7 buttons and the other has 6 buttons like mine has. I did move the hot tub to my home and had it wired to my breaker correctly.
It appears you have a Circuit board Model 108/9 which is a JP #2600-019. Hard to find compatibility for these. Here is the manual link to a spa with your processor in it.http://www.psposeidon.com/wp-content/upl...
You can see the upper controls in this manual. I did see one site listed a VS701 not a VL701 but I do not know the difference
The circuit board is labeled clearly. Each relay has a silkscreened purpose. See if you can find out which is clicking. Don't get shocked.
http://www.ebay.com/itm/Balboa-SERIAL-DE... is the link to a direct replacement for that control board based on the manual.
That is certainly not the top side control I received. mine has only 6 buttons. 1 for jets 1 for blower 1 for light 1 for mode and 2 temp bottons
If it uses the same serial protocol, it may still work fine. I would call Balboa and tell them what you have. They made the stuff, they should be able to answer this question. 1-714-384-0384
