Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Thanks.....It's a Chrysler connector, color coded, worked for almost 3 years. I can see a speaker going bad, dont understand how the balance selection disapeared from audio adjustment menu.... will try opening door panel this weekend.
Ok, to update....was doing some alternator work, after that I opened up the door, found clip holding harness broke, window regulator cut wires clean through.... repaired harness, reconnected battery....now speaker works great, balance adjusts fine.... speaker and/or reset head unit with battery off?
Thank you everyone for posting!!!
SOURCE: DEH 1700 speaker problem
here is the manual it will tell you all u need to know about this head unit http://www.pioneerelectronics.ca/pio/pe/images/portal/cit_11221/164711831DEH-1700%20OPERATION%20MANUAL.pdf
SOURCE: changing the time
Here's a link to the manual Pioneer's web site.
Here's how you set the time (from page 16 in the manual):
1: press SOURCE and hold until the unit turns off.
2: Press AUDIO repeatedly until the clock appears in the display
3: Press (left arrow) or (right arrow) to select the segment of the clock display you wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to set the clock.
- To cancel clock settings, press BAND
- to save clock settings press AUDIO until the display stops blinking
SOURCE: how do I set the speakers sound right and left front and back
press audio button till you get to either balance or fader and use the seek up and down buttons to adjust them
Testimonial: "yes it was ...bal 0 is even for right and left speakers and fade is for front and back speckers"
