Computers & Internet Logo
Sys Admin Posted on Nov 12, 2013
HP proliant DL380 gen4 PXE-E61, when trying to install redhat and solaris.
Hello, I recently bought a hp proliant dl380 g4 and was trying to install Redhat 6. I received an PXE-E61 stating: media test failed-check cable. I was wondering what my options were and how exactly could I check the cable. Thanks for any support
Bryan Gay
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Nov 17, 2013
Bryan Gay
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
3734
Points
46
First, it's not booting from a CD or Hard Disk if you've reached that error. The 'last-ditch' effort to boot is to attempt a PXE boot from the network card, but your Ethernet cable isn't plugged in. Unless you know you've setup such a PXE boot server, you'll want to check the BIOS settings to be sure the CD-ROM is set to boot first, followed by the Hard Disc. Be sure you have Disc 1 of the Linux installation set in the CD-ROM Drive and reboot. If you don't get the install screen, you may have another issue (bad CD-ROM Drive, bad cable/controller, no power to CD-ROM, etc.)
Another note on the DL380, if there is a RAID controller, you'll need to setup the RAID before installing the OS. You'll want to make sure your hard drives are properly installed and aren't failed. The RAID configuration screen will verify the RAID status once it has been initialized, which will somewhat verify the drive status.
4 Related Answers
Anonymous
  • 5 Answers
  • Posted on Jun 05, 2008
SOURCE: redhat es5
OS Supported by DL380 G4 According to HP website are : -
» Microsoft Windows 2000
» Microsoft Windows Server 2003
» Microsoft Windows Server 2003 for 64-bit Extended Systems
» Microsoft Windows Server 2008 W32
» Microsoft Windows Server 2008 x64
» Novell NetWare 5.1
» Novell NetWare 6.5
» Red Hat Enterprise Linux 2.1 (x86)
» Red Hat Enterprise Linux 3 (AMD64/EM64T)
» Red Hat Enterprise Linux 3 (x86)
» Red Hat Enterprise Linux 4 (AMD64/EM64T)
» Red Hat Enterprise Linux 4 (x86)
» Red Hat Enterprise Linux 5 Server (x86)
» Red Hat Enterprise Linux 5 Server (x86-64)
» SCO OpenServer 5
» SCO OpenServer 6
» SCO UnixWare 7
» Sun Solaris 10 x86 Platform Edition
» Sun Solaris 8 Intel Platform Edition
» Sun Solaris 9 Intel Platform Edition
» SUSE Linux Enterprise Server 10 (AMD64/EM64T)
» SUSE Linux Enterprise Server 10 (x86)
» SUSE Linux Enterprise Server 8
» SUSE Linux Enterprise Server 9 (AMD64/EM64T)
» SUSE Linux Enterprise Server 9 (x86)
» VMware ESX Server 2.5
» VMware ESX Server 3.0
so DL380 G4 does support 64 bit OS :
There are no Setting in the BIOS as such . no special settings need to be changed.
lib32 is for 32-bit and lib64 is for 64-bit obviously, If you are using a 64bit OS and these folder doesnt show then installation did not happen properly.
It seems more of a OS CD Issue . Erase the HDDs again , configure raid . use a known good RHEL CD to install .
Hope This is Helpful.
Cheers :)
a4andrew
  • 4 Answers
  • Posted on Sep 28, 2010
SOURCE: USE441A02R-ProLiant DL380 G4 HP NC7782 Gigabit
I have the same problem and have seen two possible options for resolution...try updating the NIC's firmware and it could be a motherboard problem that needs to be replaced by hp. If either of the options provides the solution, let me know. I'm in the midst of it. (I've tried updating the drivers, swapping network cables, even feeding the NIC a known connection that gives 1Gbps.)
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=407733&prodTypeId=329290&prodSeriesId=407731&swLang=8&taskId=135&swEnvOID=1005#2995
Anonymous
  • 44 Answers
  • Posted on Nov 28, 2011
SOURCE: HP Proliant Server DL380 G4 wont boot no display
Clear NVRAM.
Anonymous
  • Posted on Jan 24, 2012
SOURCE: HP DL380 G4 Video resolution
To increase the resolution on a DL380 G4 try this.
So here is what I have done.
- Download x64.zip file from ftp://ftp.supermicro.com/driver/VGA/ATI/RageXL/x64.zip
- Run/Expand the zip to same directory
- DO NOT run the setup file or you will get the error message,
"Setup will only run in Administrator mode. Setup is aborting"
- Launch Device Mgr
- Expand the Video Driver and update Standard Video Drive. Point to directory x64.
- The server will need to reboot
- Display settings can be raised from 1024x786(16bit) to 1280x1024(32bit)
Note: 1600x1200 (16bit) is available but does not work on mine. If you set it to this setting and the video does not come back, connect up a higher resolution monitor and set it back.
2answers
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c00972124
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=316587&docLocale=en_US&docId=emr_na-c00688182
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c04441382
Hp proliant dl380 g4 not booting from hard drive
I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
Hp pavilion dl380 g6 unaccepted restart
Clearly explain about your problem.
It would be HP Proliant DL380 G6 server
Sound card in Server
Yes, just make sure the card is compatible whichever flavor(s) of slots you have available and is supported by your OS.
Erorr 805 processor not supported
Is your server under carePAQ/ support by HP.
Please go to the System Settings/BIOS of the server by pressing F9 while booting. Check for error messages.
Please check for the processor support matrix also. You may want to try upgrading the motherborad firmware berfore loading this proc.
Cheers,
2answers
Redhat es5
This model was found not to be 64bit but 32bit.
Proliant DL380 G4 server occasionally rebootes.
Try to update the firmwares. Maybe the threeshould of the fans are incorrect. A new firmware can correct this problem.
Let me know if this post helps
Grand Canyon Tech
Grand Canyon Tech
