Which hole in back of my computer should the speaker wire from the monitor go into The line in or line out hole???
SOURCE: dgm monitor no sound through speakers
have you got the correct leads plugged in?
have you removed and reinstalled the device???
Have you got another set of speakers to try???
SOURCE: HP vs15 Flat Monitor
It depends what computer you have, and what version of Microsoft you have. for those of you with the Presario SR1650NX computer, here is the Latest driver: Click. For the earlier driver: Click.** to download drivers for you computer go to your computers company website (Gateway, HP, Compaq, Etc.).
**I Recommend downloading the older version first, and if it doesn't work then download the latest.
SOURCE: where do I plug in my speakers for my new H.P. 17" lcd latscreen
If the jack looks like a regular jack only it's too big, you can get an adapter that will convert the larger one to a smaller size that will fit into the computer. You can get it at any elecronics store.
SOURCE: No sound from my HP w1907 monitor
This is a failure in the audio section of the control circuit. Your cable could be at fault or the circuit itself. Try switching cables or try you monitor on a different sound source. if this does not work then it is the monitors sound circuits. This requires a trip to a service center for servicing. Hope this helps.
