My Maytag Neptune electric dryer runs with no heat, I have a multimeter to test, but what do I test and how do I read/use the multimeter?
No heat at all? open front to access heater box, set meter to ohms. (unplug dryer), test for continuity across element connections. (disco at least one wire at each part to ensure accurate results for each check. then reconnect when done) some ohms is good here. if OL on meter then its open/bad. check each thermostat on side. they should all be 0 ohms. post results.
At terminal block in rear check voltage while plugged in. set meter to volts AC. each outside terminal to center should show 120 V approx. then together 240v. if 120 only on one side or one side significantly less than 120 then check outlet. Missing one phase/leg of supply can cause motor to run but no heat.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
dryer runs without drying big loads
