No spark
Follow this steps and fix it. GOD BLESS YOU
If grass is poorly or unevenly cut, try mowing at a slower speed and
adjusting the engine speed with instructions in your owner's manual.
Scrape away any dried grass and other debris caked under the mower deck.
Sharpen or replace dull or bent blades . Check and replace a worn belt.
If the V-belt slips or comes off during use, clear any debris in the
belt area, adjust the drive-belt tension (see below), or have the belt
replaced. Adjust and tighten pulley fasteners or have a service center
replace worn parts.
If the belt squeals or wears excessively, adjust the drive-belt
tension (see below) and look for obstructions around the belt. If that
doesn't work, take the mower in for professional service.
If the mower vibrates excessively when the clutch is engaged, scrape
away any debris accumulated under the deck. Balance the blade
and replace the blade if needed. If that fails, adjust drive-belt
tension (see below). If you find that the drive belt, pulley, or other
belt-drive part is damaged, consider having it replaced by a
professional.
If the mower is hard to shift or doesn't move when the clutch is
engaged, adjust the drive-belt tension (see below). Also make sure the
mower is lubricated according to the owner's manual specifications. As
needed, have the mower serviced for damaged or maladjusted clutch/brake
pedal linkage.
If the engine doesn't start, loses power, or dies during use.
Replace a recoil starter rope:
Replace a recoil starter spring:
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
I hope you find this solution helpful. Please rate it thanks for using Fixya!
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
SOURCE: Murray riding mower Mod. #30575x8a will not start.
Hello:
You can View a Schematic at the Following Site Addy. Select the OEM Briggs and Stratton (Murray Power).
Hope this Helps.
Good Luck
Respectfully
John
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
