Timex 1440 Sports T5K085 Watch for Women Logo
Joy Seacat Posted on Nov 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Instructions to set Timex 1440 sports watch T5K085
Can't set time & if I accidentally get the time I can't get the watch to stay with that time. It reverts back to the old time.
Level 3:
  • Timex Master 18,429 Answers
  • Posted on Nov 13, 2013
Timex Master
Level 3:
Answers
18429
Questions
Helped
1404864
Points
62248
5 Related Answers
Anonymous
  • Posted on Nov 10, 2007
SOURCE: how do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Anonymous
  • Posted on Jan 05, 2008
SOURCE: How do I get instructions
The instructions at the Timex site for a 1440 seem to be for a different watch than our 1440. We eventually found our copy of the instructions and they are titled W-163-US. I found these same instructions here:
http://www.sports-watches.co.uk/watch_manuals/5e061.pdf
Anonymous
  • Posted on May 12, 2008
SOURCE: Timex 1440 sports watch, WR50M
In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
Anonymous
  • Posted on Jun 02, 2008
SOURCE: timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Anonymous
  • Posted on Feb 26, 2009
SOURCE: Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
How do I change the time on my watch cannot find the instructions.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Cannot set time on my Timex 1440 sports watch
I assume that you do not have any instructions; if that is so, then you can get instructions from the Timex web site "timex.com".
manual download"
How to set my timex watch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
7helpful
How do i set the time on a timex 1440 sports
Here you go old chap:
http://assets.timex.com/manuals/
Cheers.
3helpful
2answers
I don't know how to set my timex 1440 sports watch
1. it is easy all you have to do is hit mode
2.then you will se all zeros
3.hit mode again
4.then you will see a number blinking then press start/stop button and it will change to the next number
5.then just set it to your clock time and your done!!!!!!
hope this will help you
3helpful
I need set up instructions for a wr50m 1440 sports watch
Visit www.timex.com/ - 12k - Cached - Similar pages
Choose: SPORTS, then SPORTS1440 and download manual.
2helpful
4answers
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
