The dryer is not getting hot. The drum works and I cleaned out the lint from the hose and back of the dryer in case that was the problem.
SOURCE: kenmore gas dryer
kuki, on a gas dryer, if the thermal fuse is blown, it will rotate but will not heat. If your dryer front has a lower panel, the fuse will be in front behind the blower housing. If not, it will be in back just like this pic. Ohm it out or jump it out temp to see if that is the problem. Post back, Catriver
SOURCE: Dryer won't dry
Sounds like a ventilation issue. Remove the dryer vent tube and take a leaf blower to it and try to blow it out as best as you can. Also check outside to see if something is blocking the vent. Birds and mice love to build nests in that nice warm vent tube. The ole leaf blower will remove these nice little woodland creatures with force, yet its totally humane, and wont hurt them a bit. If this doesnt work, you may have to run to your local building supply center or hardware store and get one of those inexpensive brushes that you can use to clean out your lint areas. A good test to see if you have good airflow is to remove your lint filter (if its a top filter), turn on the unit, and drop a small piece of lint down the tunnel. If it zooms right down, then its good. If it just kinda hangs around, its not that good. If you have a way to check the entire length of the vent tube, look to be sure that there is no dips or kinks. Also, remember that the shortest and straightest vent tube, is the best vent tube. Let me know how it turns out, or if you need further information. Good Luck!!!! Jim
SOURCE: Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
SOURCE: lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
