Our ice maker was on the fritz for about 6 months and even after being repaired, the water from the door-dispenser still tastes musty & has a slight musty odor. Ice doesn't seem to have the same problem. The repairman said to just flush it by using it a lot but I haven't noticed any improvement. Peggy
SOURCE: Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
SOURCE: ice smells/tastes like chemicals
discard ice keep making it till it goes away(dont eat ice) if doesnt go away-further investigate!!! :)
SOURCE: Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
