Cell Phones Logo
p
paulchisha chisenga Posted on Nov 12, 2013
43 inch plasma samsung tv with abnormal picture size .i want to adjust but i dont have serivce menu codes please help.
Nelson Leung
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Nov 12, 2013
Nelson Leung
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
904
Points
16
Using The Remote Control Your remote control will have a button on it to quickly adjust the picture size.
  1. Press the P.SIZE button.
  1. The current picture size will be displayed on the screen.
  1. Press the P.SIZE button repeatedly until the desired picture size is selected.
  2. Important: Some picture sizes are only available with certain resolutions or certain inputs.
Using The On-Screen Menu
  1. Press the MENU button. [The Main Menu appears]
  1. The Picture portion of the Main Menu will be selected by default, if it is not selected use the directional arrows to select the Picture portion.
  1. Use the directional arrows to select Screen Adjustments, and then press ENTER.
  1. Picture Size will be selected by default if not use the directional arrows to select Picture Size, and then press ENTER.
  2. Note: The current picture size selection will be displayed to the right.
  1. Use the directional arrows to select the desired picture size, and then press ENTER.
Samsung lcd tv: why is menu bar in the middle of screen?
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Cracked screen what can I do?
Just buy a different tv, The screen is $300.00 or more, Depending where you get it from.
1helpful
Autuotune samsung 42 inch plasma
please follow this step:
you have customized the picture and menu settings on your Samsung TV only to find that they keep reverting back to their default positions, this is because your unit is in what is referred to as "Shop Mode." This is the demonstration mode used by electronic retailers to show potential buyers all the features a Samsung television supports. Press the "Info" button on your remote control, and if under the "Picture Mode" heading it reads "Shop Mode," hold down the "Menu" button on the TV itself until the screen reads "Dynamic Mode." This has changed the picture mode to one of the pre-set positions. You may now change any settings you'd like.
God bless you
2answers
Picture size is not right
You can go into your picture settings and change your aspect ratio. This should fit the picture to your screen. Sometimes depending on the model this can be done with the remote as a separate button there. Other than that it will be in your menu settings. You'll be looking for 16:9 16:10 4:3 etc etc for the sizes.
I have a 26" fluid plasma T.V. I did not recieve
If this is the remote that goes with this television, and this is not a universal remote or one for a different model it does not need to be programmed. There is often a button on the remote that adjusts the picture size. It may be wide, format, view mode, aspect, zoom, and etc. This option may also be in the menu if there is no specific button for this task. However there are reasons that the screen size will not adjust even when pressing the proper button.
Now if you are using a cable box or satellite tv receiver there may be a button on your cable or satellite remote that will adjust the picture size. It is usually hdzoom # on the cable remote and format or aspect on the satellite remote. Picture format may also be in the cable box or satellite tv receiver's menu options.
However if you are connecting with an over the air antenna or direct cable and you are watching a high definition program this sometimes happens. You will not be able to adjust the screen size. Also if you are using a cable box or satellite tv receiver and it is set at a higher resolution than what the television is designed to display then this will happen and there will be no way to adjust the picture size. The cable box or satellite tv receiver could also be connected to your television with a coaxial cable to the rf/tv input. If you are in that input rather than the av, component, or hdmi input then this can happen.
LG 42 inch picture does not fit on the tv screen horizontally
The format is set incorrectly. Go into the Picture settings in the menu and adjust the format settings until you get the size picture that you like.
Craig
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
1helpful
2answers
Picture is too wide for the screen can`t see all info on program guide on left side
you are viewing in16:9 ratio (widescreen) and your tv is 4:3 you need to change your picture settings in the tv menu
2answers
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
