Televison & Video Logo
Posted on Oct 06, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ilo 26hd I have this tv my problem is I can't not change the input source only stay in "COMPONENT" input any ideal what can be the problem?
Anonymous
Level 2:
  • Expert 363 Answers
  • Posted on Oct 06, 2007
Anonymous
Expert
Level 2:
Answers
363
Questions
0
Helped
268271
Points
867
- Does this happen even when the source in question is unplugged from the TV? -
  • Anonymous Oct 09, 2007
    Well I thought I'd look for your manual via google and was confronted by a screenful of iLo consumers complaining about their sets.
    It seems that the iLo brand is one of the worst for reliability.
    If your set is still under warrantee then take it back to Walmart or wherever you bought it.
    I hate to admit defeat but due to the sheer number of faults with these sets and the feeling you've tried everything by now makes me think this is the only course of action.
Ilo-26HD televison problems
most of the new TV's use a SCAT plug to allow connection of a PC or laptop. I doubt that this TV has that sophistication. The ISB will not do it and neither will S VIDEO.
As for the cable you could try a male to male plug to mnake a coaxial connection. These TV's were made to a price for walmart and you got what you paid for which was a cheap TV. There was no warranty offered by Walmart for these either
Please rate my help++++Thanks for using FIXYA
3helpful
2answers
Who is the manufacturer of the ILO 26HD Television?
the manufactured should be on the back of the tv- i have an ilo 27 flat lcd hdtv the name on the back is
SUPERIOR ENTERPRISES
5900 CANOGA AVE
WOODLAND HILLS CA 91367
ILO 26HD TV: After playing Playstation, the TV
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
2answers
Ilo 26HD
Well you may have to rescan for cable if you have cable if not then your tv tuner probley went out and the tv does not notice a signal. hope this helps
ILO 26HD
The ilo tv 26HD turns off by its self after about 20 min. of being on.
2answers
Ilo 26hd
Let me guess, you bought this from Walmart?
If you can return it, do so, otherwise the best place to start is to follow the inputs to the board to the screen.
One thing to try is unplug it for 8 hours to hard reset it and see if that makes a difference. These tvs have a history of having this problem and most likely the signal processor is at fault if nothing else looks bad.
ILO-26HD
Some times the mico locks up and if you unplug the tv and wait a few minutes then plug it back in, it will go to the default ant 1 input
3answers
Ilo 26hd lcd tv
I unplugged mine over night and plugged it back in this morning but it still will not turn on. It is still in standby mode
2answers
ILO-26HD remote problems
I have the same problem.
1helpful
3answers
ILO 26HD
Hi! Yes, this is a very common problem for this model of ILO TV. It is due to a problem on the controller board inside the set. I actually bought one of these with the idea of fixing it, and it took 6 months of research to figure out the problem. If you are technically capable, or if you have a TV shop in your area where the set could be disassembled, I might be able to help. Let me know.
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
