Sony VAIO RB30C (VGCRB30) PC Desktop Logo
A
Anonymous Posted on Nov 10, 2013
Reset Bios on IQ770 HP computer with monitor problems
I want to connect a HP w2207 monitor to a HP TouchSmart IQ770 PC. What is the best way to do this?
Your HP w2207 monitor has support for both VGA and DVI inputs. This therefore means that you can connect your HP TouchSmart IQ770 PC via either of these two connectors.
VGA is the blue coloured port on the rear of your monitor.
DVI is the white coloured rectangular port located on the rear of your monitor.
DVI is the better connection of the two as it is a digital connection, so use this one if you can, alternatively you can use the blue coloured VGA cable to connect your monitor to your computer.
It all depends on which output, either DVI or VGA is found on your Computer. Remember VGA is the Blue coloured port and DVI is the blue coloured port.
All the best!
damnor01
2answers
My touchsmart iq770 wont run windows vista unless im in safe mode and i have lines through my screen
Go to support.hp.com and look up your computer.
Download and install the Vista drivers.
If you don't see Vista drivers the computer won't run Vista. Go back to XP.
If this helps please vote for my solution.
2answers
HP TouchSmart IQ770 Desktop Pi have this pc bt the
If you had got any new hardware perhaps Speakers? try and make sure the speakers are not very close to the screen.Because the electromagnetic waves affect the monitor.
If not then adjust the screen resolution.Hope your problem will be solved
Thanks.
If this solution works for you,then please rate me for this.
Hp touch smart iq770 when im switch on is not showing display
check power lead to monitor, check coupling cable fron computer to monitor.or resolution is too high for monitor
No Video; (hp IQ770) You can hear it booting Properly but nothing shows on the screen. (either the monitor or video card has gone bad) How can I test to see which is the problem?
does this unit have an external monitor connector? if it does you can use another monitor to check t he output of the video card.
other than that....I think you are headed for a repair bay somewhere.
3helpful
2answers
Take Apart IQ770
Check out this web-site that was set up for "Touchsmart" owners; there are many discussions on this very topic there and one person has successfully fixed their IQ770 with a black monitor problem who has posted.
http://www.touchsmartdevzone.com/forum/thread/770/MONITOR-IS-BLACK-RESPONDS-TO-TOUCH-BUT-IS-TOTALLY-BLACK/?page=5#12182
Touchscreen does not wotk on my IQ770
check all the cable connectors, reinstall the driver, if all else fails, the touchscreen glass / controller need replacement
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
