I have a small camera w/ a SD card that says PNY 8GB on it.. It is full of my vacation, how to I restore or recover the pictures on it... They all disappeared when I went to set to set the date on the camera...
I have met this problem before. And the following links helped me recovered all my lost data. So I suggest you to have a try. Good luck!
Suddenly formatted it or something else?
If you has not put anything new on it, there is still chance for you to get it back. You can use recovery tool like 4Card Recovery to restore your files.
Have a try.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Try 4Card Recovery. It is very useful. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
You may have cleared everything by using Reset but... Put the SD card in a reader on your computer and open that directory to see what is in there... Good Luck
SOURCE: PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
SOURCE: 8gb PNY micro sd card isn't recognized in my samsung Alias
If the phone failed to format the SD card, try to format it through your computer. Connect the phone through the USB port located at the back of the tower. You'll be prompted that the PC detected 2 USB drives, the phone and the SD card. You will see it by going to My Computer folder. From there, right click the Letter drive represents the SD drive then select Format. I hope this helps.
SOURCE: My 4GB PNY Optima sd card will not read
Try the 4GB card in some other reader, or your camera, to confirm that it does work.
It's possible that your card-reader will not support anything over 2GB.
SOURCE: PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
