SOURCE: fault light on vector battery charger flashing
Make sure that you have the pos and neg on right.
SOURCE: Ive neo laptop.Problem is dead, powerLED on,battery blinks green
If its doesn't turned on (no disk/fan activity) the problem must be in power supply unit such as power button or cable. check the electric source input
SOURCE: I have an Elite Traveler Plus.
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
SOURCE: My Sony Vaio battery light remains orange
Maybe your battery was damage due to over charging it. You need to replace your battery. The desktop icon can says it's fully charged because you have plugged it and those are the indication that your battery was damage if you unplugged the AC power. The battery of the laptop are disposable and it cannot be repaire. The best solution of your problem was to replace your battery.
SOURCE: homelite trimer 18.0v charger, battery, yellow
homelite 18.0v battery charger, yellow amd green light on,won't charge,lost manual.
