My kingston pendrive opens up perfectly....properties shows correct information ..it copies the files also but does not open up the files - it shows 0 bytes . When i transfer it to other PC the files does not open up a msg is displayed "format is not supported or is corrupt"
PLZ ans
thanks !
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
Kingston Tech Support
insert 32 or 2 GB USB go to control panel administrive tools computer management disk mangement you can defragment this USB drive or you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
