Question about Dometic RM2193 Compact Refrigerator With Ice Box
Dometic rv fridge runs fine on elec, lights on gas but in one min shuts down. Dometic RV S1621 fridge runs fine with elec, when start gas operation. The burner runs for about 30 seconds then shuts off. There must be some type of flame sencor that is not working. when the flame is not senced, the unit shuts off.
  • jasonjacob1 May 11, 2010
    yep u just answered your own question
    President:
  • 704 Answers
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
  • Thomas Kray
    Thomas Kray Jul 03, 2011
    Clean ALL Push/Pull contacts - this will take care of most problems....Tom
SOURCE:
Rm2193 dometic fridge Works with gas but not on 120 how do i fix this?
Anon, Check the attached links,instruction and guides to diagnose fridge, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RV Refrigerator Repair 101 How To Diagnose Problems With RV Refrigerators...
The RV Forum Community
RV motorhome and bus conversion mechanic resource
Aug 03, 2016 | Dometic Refrigerators
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Where can i find a drip pan for a S1621 silhouette dometic rv fridge
use make and model number with brand and look in manual for it there should be a parts replacement list with phone number
May 26, 2014 | Dometic RGE400 Top Freezer Refrigerator
My dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
May 14, 2010 | Dometic RM2852 Refrigerator
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
I have a rv with the Dometic RM2852 refridg. It works fine on gas, but when I switch to AC input the gas turns off like normally should but the refridg does not cool. The Auto light is on, 120VAC is OK at...
First thing to check is that the control switches are in the proper position, since some RV fridges require a particular placement for the fridge to operate on different power souces.
Check your owner's manual for troubleshooting steps for your specific fridge, beyond that, here's link to a site that provides a step-by-step troubleshooting guide complete with active links for each potential issue.
http://gasrefrigeration.net/works_on_gas_but_does_not_work_o.htm
Here's a copy of the manual for your fridge model that you can download and print for free, just in case you don't have yours handy.
http://gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Hope you found this very helpful and best regards!
Aug 08, 2009 | Dometic Refrigerators
Royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Jun 08, 2009 | Dometic RM2852 Refrigerator
RV refrigerator works fine on AC power. Burns for 30 seconds on gas power then shuts off.
tap on the gas valve with a wrench,not too hard but not too light about 10 times,the valve is probably sticky from not being used,re-light and see what happens.
May 10, 2009 | Dometic RM2652 Refrigerator
Dometic RM2193 Compact Refrigerator With Ice Box Logo
1,132 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
Paul G
Paul G
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
