Konica Minolta bizhub C351 All-In-One Laser Printer Logo
A
Anonymous Posted on Nov 12, 2013
Error 2703 en konica minolta bizhub 750 - Konica Minolta bizhub C351 All-In-One Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 03, 2020
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913734
Points
11960
Directly below the drum is the transfer and separation ration unit. which houses two very, very thin gold plated wires the one on the right is the transfer wire which transfers the image off the drum on to the paper as the paper goes over the wire while the drum place the image on the paper. the second wire is separation wire which has an AC signal on it to prevent the paper from sticking to the drum. The second wire might be broken. Have it replaced best to have booth done at the same time since unit comes out? or the spring at rear of the unit are not making good electrical contacts. Ensure power is off. as they do carry High Voltage during the normal operation.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on May 25, 2009
SOURCE: KONICA MINOLTA BIZHUB 750 WITH ERROR CODE C8301
It is a code relating to FM1 fan. The fan is the one on the rear of the machine top right corner behind an ozone filter. If the fan is ok could be a blown icp. *PLEASE NOTE: I WOULD NOT ADVISE YOU REMOVE ANY PANELS OR CARRY OUT ANY ELECTRICAL WORK UNLESS YOU KNOW WHAT YOU ARE DOING AND THE COPIER IS UNPLUGGED FROM THE MAINS SUPPLY*
Anonymous
  • 51 Answers
  • Posted on Aug 30, 2009
SOURCE: konica minolta bizhub
whot is the error code and whot model of bizhub u have???
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Anonymous
  • Posted on Sep 15, 2011
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
I have a konica minolta, bizhub 750 that is showing an error massage 'c2401. can someone help?
Thread Bizhub 750 error code 2401
Maybe the link above will help. I found it by a google search, and unfortunately I am not familiar with that model.
Error code C-2703 Bizhub 500
bersihkan rumah korona bawah, dan ganti kawatnya
Rror 2703
Subject:
C-2702 and/or C-2703 code.
Description:
Solution:
PROBABLE CAUSES:
1. Failed T/S corona.
Remove the T/S corona unit. If blank copies can be printed without a service code appearing, replace the T/S corona unit (p/n 57AA R715 00).
2. The HV unit has failed.
Replace the HV unit (p/n 56AA 8401 2).
Por que impressora konica minolta bizhub c6000 apresenta error 2703
Check the Cyan Charge Corona housing. Remove it and reseat it. IF not that check the HV board. and or connection at the back of the drum and transfer middle assy.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error 2703 en bizhub 600
If the problem persists initialize the Fax board (Service Mode =>Fax =>Initialization
2answers
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
5helpful
Please help me for code c2703 on bizhub 750, thanks b4
I have a machine Minolta 950 always appears incorrect code C-2703 I wanted to know what the cause of the problem and how to solve
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
