Computers & Internet Logo
P
Paul Hunks Posted on Nov 11, 2013
Msi vr600x won't start.
Power button light and front status light come on...but that's it.
1 Related Answer
ghost2233
Hans Pedersen
  • 3606 Answers
  • Posted on Apr 01, 2013
SOURCE: Hi there I have a msi fx603 that won't start when you hit the power button it flashes once then when you let it up it flashes once more but wont start ...the only other thing that happens is the m
Hello here is the msi homepage:
http://www.msi.com/product/nb/FX603.html#/?div=Driver&os=Win7%2064
I think your harddrive is dead, and must be renewed.
The fault could also be the mainboard itselves.
A computer repair shop, can help you with that.
Good luck
The 3rd light on the front of msi workstation is blinking red and white
the manual tells this.
it means I am sleeping now.
push PC power button for 10 seconds and release
or hammer the space key to unsleep it.
but power button way always works.
Reset tablet c
These steps came from the MSI website itself. link
Restore with reset button
1. First turn the powericon1.png off the router and press the "reset" button.
2. Power on the router and hold the reset button until M1 & M2 LED or Status start flashing.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if theLED lighticon1.png flashes twice you need to repeat the steps.
Reset the router while the power is on.
1. Press and hold the reset button for about 5 seconds M1 should flash 5 times, release the reset button and the restore/reset process is done.
[Answer supplied by Aris C on Fixya.com]
Good luck
2helpful
2answers
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
1helpful
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
My MSI computer won't startup. It has an
It appears that you have only checked the power supply and the on/off button. There are many reasons a computer won't start.
These are only two. Have you "stripped down" the system? This means removing everything but the CPU, Memory, and video card. If it starts with only these things attached, then you can rule out the mainboard, memory, and video.
Next remove the memory. If it starts but you get memory error beeps, then it could be one of the memory modules.
After all that, you can then figure it's the mainboard or the CPU.
As for circuit diagram, I would think these would be very hard to find.
My Compaq Presario F756nr will not turn on. The blue light to the power cord is on and blue light on front of laptop is orange but when you press the power on button it comes on then goes right off.
Hold the Power button and at the same time attempt to continually press the button for the CD/DVD drive. Continue until the status lights for power, hard drive and power button stay on for 3 seconds or longer. When status lights remain on, remove your finger from power button and allow the machine to boot as usual. Enjoy.
Yellow light on top front panel left hand side, what is this warnign for?
Couple options . pint a status report by holding down the main button until the printer starts making noise. Or browse the menus for Then look at the printed report for Toner, Drum, ect usage. Or if its a network printer Surf to the printers IP address and look at the status pages of the printer. last option. browse the menus with the button look for menu button >> information > something like status report cheers . ps sometimes yellow is "sleep" meaning power saver mode.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
