Feature **8463 should ask for a password **266344 this should allow you to change the time. Note the time is the same on all phones in the system not just yours.
Depending on your phone's brand and model, you may have an option in its settings menu to change the time.
Many phones get their time from the signal from their cellular provider - I have noticed my phone changing its time, after the fall or spring time change, immediately after placing a phone call after the 2 or 3 am time shift has occurred.
if you are trying to change for one phone its not possible because the time changes for all the phones and if that is ok with you go to asa and give the command change time in that it will give you the options.
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
1) press "Program", then * *, then 1234, 2) press "0 0 0", 3) press "speaker" two times, 4) change the time 5) press "store". 6) pick up the receiver to complete the change.
Do this change on the "lead" phone and it will reset all the others on your system. Not exactly an intuitive process to be sure!
This is a phone system phone. The time is stored in the main control unit, not the telephone. You will need instructions for changing the time in your system and the phone's part number will not help you.
Your phone system should start with the part number "KX-TGA" KX-TGA????
Here is a link to a site that has time change instructions: http://www.tel-programmer.com/Time%20setting/panasonic_time.htm
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM 99 on a display phone and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following:
Press PROGRAM * * 1234(Default password is 1234. yours may have been changed)
Press SP-PHONE 2 Times.
To change the year enter the two digit year.
If it is correct press FWD/DND to move the flashing indicator.
MONTH is changed by pressing the AUTO ANSWER /MUTE key.
DAY is entered as 1 or 2 digit day.
DAY OF THE WEEK is entered by pressing the AUTO ANSWER/MUTE key.
Press STORE to save your changes.
Press SP-PHONE
Enter 2 digit hour (Hour is flashing).
Press FWD/DND button(Minute starts flashing).
Enter 2-digit minute(Minute is flashing).
Auto Dial/Store Button New time is stored.
Lift handset and hang up to leave programming mode
