Nortel Norstar M7208 Telephone Logo
j
jass Posted on Nov 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display shows "message" but no message in voicemail
Displaying "message" but no message in voicemail
Greg Loechel
Level 2:
Sergeant:
  • Expert 283 Answers
  • Posted on Nov 16, 2013
 Greg Loechel
Expert
Level 2:
Sergeant:
Answers
283
Questions
Helped
56403
Points
874
Dial 101 and follow the prompts. Otherwise look for a reset underneath and hold for 5 -10 sec.
KXTG9341 Top light flashing and 'New Voicemail' message on handset display, but no new message recorded on the answering machine.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone.
Please contact your telephone company for instructions on accessing their voicemail system.
Displaying "message" but not message in voicemail
THis is usually because it thinks that there is something there, but the code path to 'clear it" doesn't follow the same logic path. Sometimes, adding a new message - i.e. dial your number from elsewhere, to create a real message waiting, and then clearing that, resets this.
2helpful
2answers
VM is always showing on display - however, there are no messages. How can I remove?
You have unheard messages on the voicemail system provided by your telephone service provider. This system records messages when people call while you're already on the phone. Please contact your telephone service provider for instructions on accessing their voicemail system.
1helpful
VOICEMAIL iCON ALWAYS DISPLAYED
Your provider can remove the voicemail icon on you screen but you have to contact them of course. Sometimes what happens is the voicemail is exited improperly and what you'll need to do it get back into your voicemail and follow the prompts to exit the system (I believe it is the star button to exit voicemail). What I would do is leave yourself a message, call into your voicemail, delete the message and exit the system. If icon is still on the screen then you have no choice but to contact provider. Good luck and hope this helped.
5helpful
Voice Message Icon always displaying
The voice mail symbol is sent to your handset by the network when you get a voicemail, they then send the handset another message to remove the icon once you have listened to the voicemail... Sometimes an error occurs and the phone doesnt receive the removal message...
Try getting a friend or using another phone send yourself a voicemail, then using your phone, check your voicemails, listen to the one you have and delete it... The icon should go... However if its a hardware fault with the handset display then this will not fix it...
1helpful
2answers
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
2answers
Display always shows "Message for you"
Phone company should be able to fix this. Generally if you don't have the code to enter the phones system, you won't be able to clear it.
Display shows "1 new/1 saved" yet mailbox empty.
The message left on your phone was probably left by someone internal, meaning they called your phone and when you did not answer, they hit their message key which turns on your message lamp and display. If you press your message key and it rings someone in the office then they are the one that left the message and they have to answer your call. You can usually cancel the lamp/message on your phone by pressing " Intercom ( your extension button ) " # 4 0 9 and then hang up. You can have up to four ( 4 ) messages on the phone so it may take putting in the code a couple of times to clear the display.
2answers
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i have, might help you guys out
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
