Car Audio & Video Logo
Brandon stites Posted on Nov 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ok so i have a Pioneer DEH-P5200HD it started shorting out when i replaced my ignition . Now it wont power on . If i run a new power wire by connecting red an yellow wires "ignition an 12v to battery together to a toggle an inline fuse an replace the ground . Would that work ? Or any suggestions to a fix ?
  • Brandon stites Nov 11, 2013
    well if it helps any i got a 91 Volkswagen Golf GTI . i am getting power thru yellow cable "12 volt supply" i am not getting any power thru the red "ignition switch 12 v dc " i do need to install a new ground tho too easy . Also when i hooked it up my amp lights came on but nothing thru deck or face plate , i tried the reset button and nothing ....
Boz
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 77 Answers
  • Posted on Nov 14, 2013
Boz
Expert
Level 2:
Night Owl:
Answers
77
Questions
0
Helped
22767
Points
185
Sounds like something was shorted out while replacing your ignition or you damaged a ground wire. You can try connecting just the 12+vdc switched lead to 12+vdc power and then ground the receiver to a chassis ground somewhere else to see if it is just a grounding issue. The yellow lead (memory) will also need to be connected in higher end units such as Alpine as the audio amp pulls from the memory lead rather than switched lead.
1 Related Answer
jturcotte
Jeffrey Turcotte
  • 8991 Answers
  • Posted on May 23, 2011
SOURCE: Installing Pioneer DEH 1500. Power
Hi, are you talking about the colors of the head unit wires or the car wires? Please tell me your car model and year.
How do you get usb to work on my htc phone
Why do you need usb to play the pandora radio app?
In audio settings the Preout setting won't stay locked in. It keeps defaulting to "rear speakers" so no signal is outputed through the RCA jacks to the amp/sub. Can anyone help? Thanks!
If you had it professionally installed have it looked at. If you done it your self then check the wiring and make sure the wires are done clrrectly. Check the ground
Pioneer DEH-P5200HD after I replaced a fuse the subwoofer stoped working. I checked the speaker and the amp. Its the radio that doesnt give signal to the amp. Also I tried turning on and off the sub in the...
It sounds like the remote turn on wire from the radio no longer outputs power. You can try connecting the the remote turn on wire from the amp to the accessory power of the radio. Place a 10 amp fuse in line just in case the issue is the amp.
I'm trying to install a pioneer DEH-64BT radio in
Check the ariel fuse with the power supply (+Ve) wire for open. If it found OK, measure the main voltage that come to that fuse carrier. You must have knoledge to use a multimeter. If fuse is found blown up, do understand that, there is some wiring mistake, caused a short circuit.
Chekc the wirings once again and replace the fuse only after that.
I have stacic when the engine is running on the cd player
This is because of a ground loop. Your radio is already grounded through your antenna. Unhook the radio ground wire (black wire) and tape it off. This will get rid of your engine static in the speakers.
I bought a car stereo but it wont save presets.
make sure you have the yellow fuse wire hooked up to bat. power (always hot) red wire is your ignition power
Pioneer DEH-1500 installation issues
Get a new unit. The damage was done before the smoke was present.
2answers
Red wire Pioneer MP 2050?
yes you can. but you risk battery drain in the long run. the ignition switch provides that feature for you... doesnt the old head unit have the wire for that? (red and yellow)
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
