I bought a mtx terminator amp model no TNA251 600 watt and two subs installed. It works good for few days but now its not cranking up proper bass and sound. It always has three solid red lights everytime. Not sure problem is in amp or stereo unit. Stereo unit is of JVC XR616. I have added some pictures for reference. If anyone can please help?
SOURCE: My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
SOURCE: mosfet 760 watt pioneer amplifier
Check all ground cables from your truck's stereo and amplifier as well. Sometimes when ground cables get loose you hear those thumping noise in your subs. GOOD LUCK!!
SOURCE: Everything works fine but my amp light is red.
if its not coming on it usually means you have a bad ground if it works for a little while then does it then its over heating and you will need to get a fan
