Cars & Trucks Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 Infinity QX4. Door Open warning light
1999 Infinity QX4. Door Open warning light flickers when making right-hand turn. All doors are secure. ? location of sensors for open door?
Thanks in advance.
Mike Butler
Level 3:
  • Infiniti Master 6,674 Answers
  • Posted on May 03, 2009
Mike Butler
Infiniti Master
Level 3:
Answers
6674
Questions
10
Helped
2895142
Points
19845
Usually on post where door closes, or in jamb by hinge area. Open door & try pushing any button/pin like object or may be a lever style too, with thumb or finger.When interior light goes out, you found it
2helpful
How do I prevent the interior lights from coming on when driver's door is open - disable the sensor on the driver's door -- 1999 Nissan Quest.
Can you tape a coin or two onto the door at the spot that hits the light switch? If not, just remove the bulbs.
1999 Plymouth breeze door light keeps flickering on and off and my doot locks keep latching up and down
that sounds like the central locking controlling lock is malfunctioning , if it is the drivers door then that lock is the control lock and need replacing
1helpful
2answers
Interior lights flicker on and off with warning that doors are open sign on dashboard comes on at same time
Open each door (one at a time) with the car running and parked.
Look for the small contact switch that tells the car the door is open/shut.
See image for location.
Press that switch in firmly and watch the dash to see if the light comes on while you are pressing.
This will tell you which one of the switches is bad.
2helpful
How you turn off warning light door open light
there is a bad door sensor on one of your doors or the rear hatch. This is a tedious process go to each door with the other doors closed and unplug sensor till light goes off.
3helpful
2answers
While driving a bell ringing happens when i make a right turn. sometimes the bell rings continually while i'm driving. what the problem?
Sounds silly but this is how i fixed my bell ringing. !st the ringing is the alarm when you open the door and the key is in the ignition or the car is running. I found the push switches that are on the side of the car and are operated when the door is shut have become loose. All you need to do is tighten them up a bit and the bell ringing will stop. When you make your right turn you probably push a bit on the door and that helps open the switch more. The switches are the contact switches that turn on the light as well as the warning sensors for open door. See if your dome lights flicker a bit as well.
The door ajar light remains on which keeps my interior lights on in my 99 lincoln town car
Making an assumption that the TC and the F150 use the same door latch warning indicator.
If this is the case, spraying the door latch with WD-40 really well should cure the problem. Spray the latch, open and close the door a few times, and spray again.
The switch is part of the door latch on the F150, and this is the input sent to the warning system.
1helpful
Door ajar warning light comes on and stays on even though all doors are secure.Sometimes the warning light goes out, only to go off again when car is locked 4 the night triggering car alarm.My guess is the...
switches are in the latch and you will have to start by turning the ignition key to on and then open and close each door. when you get to the door that doesn't make a chime sound when opened or closed. that is the door with the latch problem. you will need to replace the switch for that latch
1helpful
3answers
How can I fix a door adjar error on a 1999 Lincoln Continental? When the drivers door is shut, the warning comes on and the dome lights remain on. I don't want to spend money to replace the sensor, but can...
I suspect you have a bad door ajar switch on one of your doors.
The switch is on the door latch. try pushing each door in with your hand one at a time and see if the warning goes away.
The Lighting control module is $500 and controls a lot of the vehicle functions. It is part of the headlamp switch. It has to be configured by the dealer with his NGS tester before it will work. Ebay has them cheap sometimes. Only buy Continental LCM for your model year.
info
When at least one door is ajar and the key is in the RUN position, the door ajar cluster lamp is activated and remains on until all doors are closed. A warning tone will sound once any time the key is in the ignition switch and any door is open.
Visual Inspection Chart Mechanical Electrical
  • Door ajar switches.
  • Fuse junction panel fuse 28 (10A), 4 (10A), 5 (10A).
  • Power distribution box fuse 6 (60A).
  • Circuitry.
  • Damaged or corroded connectors.
  • Lighting control module (LCM)
  • Driver door module (DDM).
  • Virtual image cluster (VIC).
  • Restraint control module (RCM).
  • Low tire pressure module.
  • The Door Ajar Chime Does Not Operate Properly
  • LCM.
  • Driver door ajar switch.
  • Passenger door ajar switches.
  • Key warning switch.
  • Circuitry.
remove the door trim panel to access the door ajar switch.
Remove the door open warning switch by turning it counterclockwise.
Trim Panel —Front Door Removal
  1. Remove the screw cover.
  1. Remove the screws.
  1. Remove the front door trim panel (23942) from the door.
  1. Disconnect the electrical connectors and remove the front door trim panel.
Installation
  1. Follow the removal procedure in reverse order.
2helpful
3answers
2003 Volkswagen Jetta Door Ajar Light wont turn off and car alarm
it is your door switch.you need to replace it.since the door is open as far as the computer is concerned,it will set off the alarm.
1helpful
BMW 318 SE warning light
I drive a 2000 5series and the only light that sounds similar is the radiator low water warning light. worth a check.
Top Infiniti Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Infiniti Expert? Answer questions, earn points and help others
