Maytag Neptune MDG5500AW Gas Dryer Logo
Posted on May 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panel lights wont come on and wont run but light is on when open door
Anonymous
Level 2:
Sergeant:
  • Expert 291 Answers
  • Posted on May 02, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
291
Questions
0
Helped
93266
Points
784
Yes, the control board thats out. the front control pannel circuit board has to be replaced.but if the machine is new.as it has two year warranty.so you clain it if its under two years.otherwise replacing the board is necessary.its confirmed the board is faulty.
you can get the board at
www.repairclinic.com
the part number for the board is # as ---AP3882440---
please do rate the solution.thank you for using fixya.keep updated.thanks.
Why wont my mocrowave run?
If the light on the control panel and the light inside are on when door is open the unit is probably dead, however if no lights anywhere on the unit you could have a tripped breaker in your house or a bad wall receptacle.
Front panel wont light up, why?
I have the same issue. Dryer lights when door is opened, but no panel display, and no function.
Kenmore elite HE3 drum light always on, wont run
Ohm out the door switch if the light won't go out electronic control thinks the door is open.
Mar 31, 2014 • Dryers
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Whirlpool duet gas dryer is not working. The lights on the control panel are on. My husband has replaced the thermal fuse, thermistor and the motor. Still will not run. Please help.
check the door switch,if this switch is bad dryer wont work,this is a spdt type switch as it runs the drum light when doors open and lets machine start and operate with door closed
Pt cruiser tail lights front light & driverds door wont open
The headlight, brake and turn signal all run out of the turn signal switch. this is what causing you to loose those items. the door is a clip that has broken inside the door that goes to the handle, you will have to take the door panel off to find the rod that is hanging
2answers
The light on my dash saying the door is open wont
Hi
they have little pin switches on the inside of the door jar's check all these are pushing in and then back out when the door is open, they stick internally sometimes and you have to wd-40 them to free them up.
Also is the door light the same one for the boot? or is that another light? if it is a shared light for both then check the boot lid underside and the small panel on the bottom where your knees would be ensure these are all clean and have a good contact.
If no joy please get back to me.
7helpful
3answers
1997 ford exibition xlt my interior light and running board lights wont go off along wiith the door ajar light on dash board. please help
Take some WD40 and open the doors and spray a liberal amount into each of the door latches. Then open and close the doors firmly several times. This will work most of the time to unstick the ajar switches.
2helpful
2answers
The light will not turn off and dryer wont run
CK,
There's a switch behind the dryer door. Push it in and out with your finger, you should here it "click, click, click" and the light should go on and off. If it doesn't, you'll need to replace the door switch.
If that's the case, I'll need the full model number. It's on a sticker on the front panel behind the door. (it should be like three digits, decimal point and about 7 more numbers... 110.*******) With that number, I'll be able to look up parts for you and guide you through this easy repair.
SG
9helpful
3answers
Change oil light remains on after oil change and light over license plate does not work after bulb change
To reset the Change Oil Light: Open driver's door and open fuse access panel
Turn ignition key to on (don't crank the starter) Push reset button located in fuse panel When Change Oil Light starts to flash Press and hold reset button until it beeps and light goes off Repace panel
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
