Question about RIM BlackBerry Storm 9530 Smartphone
Red led light is flashing while charging and it won't turn on
My blackberry won't charge, the red led light keeps flashing but it won't turn on, what can i do to fix this problem
  • 3 more comments
  • Anonymous May 03, 2009
    how to reset blackberry storm to factory settings
  • Anonymous May 06, 2009
    I had the same issue, I removed the battery and replaced, charged unit overnight....still nothing. When i plugged it into the computer the phone was NOT recognized by the computer.
  • Anonymous May 15, 2009
    same problem, i turned it off while i was in a no mobiles area at work, turned it on again when i got home and it turned on ok, but a few minutes later the screen flashed, then went black and now it won't turn on. i'm currently trying to charge it for ages to see if that helps.
  • Anonymous Mar 20, 2014
    HTC Desire SV not turning on. Red LED flashing while charging but wont charge
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
Posted on May 05, 2009
    New Friend:
Red light is flashing while charging, but phone wont come up
Posted on Jun 17, 2013
SOURCE:
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
My blackberry 9700 keeps vibrating and flashing a green light every few minutes
Hello you may have enable your led lighting on the blackberrry . Blue ii s the bluetooth. red is charginf green is data coming down. Yellow ie a warning that the bateery charge is low.you go into options and then scroll down do you want to enable led lighting just switch it to off. OKay hope this can help you. You can also do a battery pull and reset the phone afterwards.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Nov 06, 2010 | RIM BlackBerry Bold 9700 Smartphone
My blackberry 8310 died and wontt turn back on..i charge itt and the lcd red light just comes on
can u c the battery sign after the led light goes off with a red line or with a charging line?
Apr 25, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry storm wont turn on
it sounds like *********** Borad - or The Circuit Borad on the Phone might be damaged.
Did you drop it?
Mar 31, 2010 | RIM BlackBerry Storm 9530 Smartphone
Red LED light keeps flashing after I open a message
The red light is telling you that your phone is on. It will flash regaurdless if you have a text or not. When you charge it the light turns green.
Thats how they're made :)
Jul 02, 2009 | RIM BlackBerry Pearl 8100
My NEW Blackberry 8310 won't charge! Red light flashes just once.
get a message saying my USB is not sufficient enough to charge phone ???? It works on other computers just not the one I need it to work on.
May 09, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Pearl 8100
let it charge till the light stop flashing
May 21, 2008 | RIM BlackBerry Pearl 8100
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Blackberry 7290 - Will not trun on
Unit is defective or the software needs to be reset/reflashed.
- J.
Mar 12, 2008 | RIM BlackBerry 7290
RIM BlackBerry Storm 9530 Smartphone Logo
5,709 people viewed this question
Top RIM Cell Phones Experts
RONALD CARTER JR
gggg
Ekse
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
