Kodak EasyShare V1003 Digital Camera Logo
Anonymous Posted on May 02, 2009
I have a Kodak Easy Share v1003 ... but no install disc, and I have a new computer .... Plz. help I really would love to upload my pic's to my computer and change info.on myKodak . Thank You
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Oct 17, 2012
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443202
Points
622693
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
You may view/download the user guide here.
1 Related Answer
Anonymous
  • 30 Answers
  • Posted on May 09, 2009
SOURCE: no install disc
Go to Kodak.com and download an install disk for your camera model. It is free.
Kodak easy share is frozen on the Easy share page
Remove the battery and the memory card, and disconnect from computer, now push power and hold for at least 60 seconds to reset the processor ic, install memory card and battery, turn on camera settings should return to normal, if not! the systems control board is the problem.
Apr 16, 2012 • Cameras
MY COMPUTER CRASHES EVERY TIME I TRY TO UPLOAD PICS AND THEY WANT UPLOAD HELP THIS HAS SHORT VIDEO CLIPS AS WELL IT WILL GO THROUGH THE PROCESS OF SEEING IF THERE ARE DUPLICATES AND AFTER THAT IT ACTS LIKE...
Please reinstall your version of Easy Share software:
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
1helpful
I was downloading my pictures from my kodak easy share v1003 to the easy share program. the camera was recognized the downloading showed up as downloading to a file foler by date. it finished downloading,...
I?ll be fine. All your original pictures are on the C drive. Unless you have changed the directory onto which you save when transferring: You can find the pictures under C-Drive, my pictures. The camera might need to be recharged. The camera doesn't charge from the computer while transferring pics. You will need to switch the camera off before the camera will start charging.
1helpful
Can't get easyshare to start download
If this fault message is on your computer starting Easy Share Software: Please do a Clean Install on the software:
    1. Select Start > Settings > Control Panel > Add / Remove Programs.
    2. Select Kodak Easy Share software.
    3. Select Remove (or select Change, and then select Remove).
  2. Run the Clear utility:
    1. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
    2. Click the Download button, and then follow the on-screen prompts.
  3. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
No install disc
I lost everything when I moved
I have a Kodak EasyShare v1003 ... but no install disc, and I have a new computer .... Plz. help I really would love to upload my pic's to my computer and change info.on my Kodak . Thank You
Downloading photos
If you are using Windows XP unplug your camera from your PC and uninstall the Kodak software. You don't need it to transfer photos to your PC. The next time you connect your camera (turn the camera on) to your computer it should recognize it and you can use Windows built in transfer software. Details are here:http://www.organizepictures.com/2006/11/5-easy-steps-to-transfer-your-pictures-using-windows-xp-photo-wizard
Kodak easy share v1003 with broken lcd how i can fix this cheap
Sirs I have a Kodak easy share v1003 showing the screen completely white. How can I replace it... seems that I already find the spare part in e-bay. Can I do this replacement by mayself?
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
