Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Kenmore upright freezer no digtal light no motor running
Light inside freezer comes on
no light on door
no motor running
also had power failure
  • smasun1 May 03, 2009
    I HAVE A UPRIGHT FREEZER MODEL 253.21041105 AND THE YELLOW LIGHT BY THE HANDLE WILL NOT LIGHT UP NO MOTOR RUNNING BUT LIGHT INSIDE FREEZER COMES ON.
    I DO NOT HAVE A DIGITAL DISPLAY.
    I HAVE PREVOUISLY RECEIVED A CAUSE BUT I FELT THAT I DID NOT DESCRIBE IT FULLY. IF IT IS A ELECTRONIC CONTROLLER WHERE IS IT LOCATED
  • 323 Answers
This could be a bad controller since you had a power outage, or even a bad motor. Look in your operator's manual and see if there is a reset button somewhere near the motor.
Unless you are well versed in electronics and have the proper equipment, you'll be unable to diagnose the control board anyway.
As a last ditch effort, which sometimes works, unplug it for about 5 minutes and then plug it back in. Make sure your thermostat is turned to the correct setting.
Posted on May 12, 2009
  • 68 Answers
If it is an electronic control freezer then the electronic control sounds as though it has failed if there is no digital read out
Posted on May 03, 2009
SOURCE:
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
No light on door and motor not running
Have you checked your breaker switches in the circuit box? If tripped, the breaker will rest in a half way position.
Turn it all the way off and then back on.
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Mar 21, 2009 | Kenmore Freezers
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
497 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Jay Finke
Jay Finke
geapptech
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
