A
Anonymous Posted on Nov 10, 2013
My Sony VPL-FE40 projector shows white vertical lines. this makes the overall screen display whitish
5 Related Answers
stilyou
  • Posted on Feb 02, 2008
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Anonymous
  • Posted on Mar 25, 2008
SOURCE: Projector shows only 50% of the computer screen
mine does the same thing but i can see the whole screen it's just half height full width, above solution about zooming to 1X is what i've been doing to fix it for the last 6 months, needs to be done every time I turn the power back on. Anybody know of a more perminate fix?
Now my power supply has gone have the projector in pieces, found a failed on transistor but because it's over heated can't read of it what type it was....
Already replaced two blown diodes in the main H-bridge
Looks like one coil will need rewinding.
If anybody has one in pieces I would be great if you can help me work out what the blown transistor was.
Anonymous
  • 563 Answers
  • Posted on Apr 01, 2008
SOURCE: White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Anonymous
  • Posted on Feb 17, 2009
SOURCE: Blue Haze on screen Sony cineza vpl-hs50 projector
I also have the same problem -- the fix is to replace the optical block ( Internal lamp engine ) which is a $1,100 part. I just purchased a used projector for half the price of the part.
Anonymous
  • 8 Answers
  • Posted on May 25, 2009
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Sony VPL FE40 BUTTON POWER green light , after standby six flashes. help
That is an internal electronic failure. Could be a ballast, mainboard, any number of things. Not a user repariable issue. http://www.projectorcentral.com/pdf/projector_manual_3594.pdf
More info is on page 47 in the manual that I linked.
How do I enter servicemans menu on a SONY FE40?
1,turn on the projector
2, press the following keys on the control panel of projector ( or on the Remote Commander) in the following order for less than five seconds each:enter,enter ,up,down,enter.
3,ok
Note: enter,enter ,left ,enter, is another way for advance Menu.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
http://www.lampdeng.com
Sony VPL-ES2 projector getting vertical lines in screen
the LCD panel is broken,
you need a new one USD100
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
My screen has a blue cast over everything. On a clear screen you see blue lines running up and down the viewing picture
I have the same problem with blue vertical lines all over the picture... did you find a solution?
Make and Model: Sony VPL-PX31 projector. I've started seeing black and white lines flash throughout the screen. I've heard this might be a problem with the mainboard. If so, what is it's...
Hey,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this helpout in solving....
3helpful
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Sony VPL-HS50, any viewing (TV, DVD) a spread of blue appears on various parts of the screen, generally contained to the sides but from top to botom. Just recently a large yellow blotch appeared in the...
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
