Acer Aspire 5000 Notebook Logo
C
Chris Carter Posted on Nov 11, 2013
Cant log on to wireless web
Cant log on to wireless talktalk
t3chn0vamp
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 30 Answers
  • Posted on Nov 12, 2013
t3chn0vamp
Contributor
Level 1:
New Friend:
Cheetah:
Answers
30
Questions
0
Helped
1928
Points
63
Check the password.
Talktalk my account
you should be able to setup WLM as follows
http://help2.talktalk.co.uk/set-windows-live-mail-talktalk
Paypal login account
Point your web browser at http://www.paypal.com then click the "Log In" button in the upper-right.
1helpful
Talktalk mail log in
If your having problems gaining access your best option might be talktalks help page: http://help2.talktalk.co.uk/
Cant connect to the internrt via talktalk modem
This could easily be an issue with either your TalkTalk internet connection or your Wii. I did experience issues connecting my Nintendo Wii console at first too, but after getting a new router, it works just fine.
The Nintendo Wii console has never been a very good internet-enabled console anyway, and alot of wireless settings will not be compatible with it.
Make sure that your TalkTalk router is using WEP or WPA-PSK security. You can also try changing the Wireless Channel and MTU Size. make sure the MTU size is set at 1450, the channel can be anything, but only a few should work. You can access these settings easily by just going to Internet Explorer and typing in:
  1. 192.168.1.1 for D-Link and Huawei
  2. 192.168.0.1 for Netgear
  3. 192.168.1.254 for Thompson Speedtouch
If TalkTalk did supply your router, then it should be one of the models mentioned above.
If you have any laptops or phones that use the wireless and it works fine, then it may just be the Wii console. TalkTalk will not support the Wii or any video game console so there's no point in calling them for support.
I work for TalkTalk as a senior technician, so I hope this information helps.
Take Care.
2answers
Belkin FSD7632-4 v8 wireless router will not connect to my ISP
It should be ok aslong as it is in sync. Can you tell me what router settings your using for talktalk? It should be PPPoA, Vc Mux, Mtu of 1432, Idle of 0. Ip assigned by isp is yes. Also make sure your username and password is correct.The username is going to be
[email protected] and password is as provided by talktalk. IF your getting stable sync on the belkin the distance and noise levels shouldnt be causing an issue.
2helpful
Webmail.talktalk.net does not accept mypass word. Have used it for years,acer laptop
If you normally use POP3 to access your TalkTalk e-mail and haven't used Webmail for a while you may find that you can no longer log in. I have seen just a few isolated cases of this.
I'm not sure why but to fix it log into www.talktalk.net and access the Broadband Dashboard which is located on the left hand side under Broadband / Manage Broadband Features. Choose
  • Now sign in again, SIGH!, using your telephone-number@talktalk.net and your broadband password. If you have forgotten your password then just call 08700 875562 from your TalkTalk landline and follow the instructions.
  • Select the e-mail tab and enter a new password (or even the same password) against the e-mail address you are having problems with and then press UPDATE.
  • Now you can go back to webmail.talktalk.net and you should be able to sign in using the e-mail address and password. If its your first time on the new e-mail platform then you will be asked to fill in some extra details such as your name, gender and date of birth and press submit them.
Webmail should now be working again.
Model dsl 2640r how can i secure my wireless network and stop strangers logging on with these being gharged to my account with talktalk
You can put on a password for internet access for all wireless networks to prevent these strangers logging on.
Have philips wireless modem from talktalk but dont have installation disc. need to install mamnually
I think this is a wireless router, and therefore does not need an installation disk.
all you need to do is connect to the router (using a lan cable if you cannot connect to it wirelessly) the default IP address should be 192.168.2.1 type this ip into IE you should get a configuration page and then you should then be able to configure the rest of the settings yourself
see info below
http://www.talktalk.co.uk/talktalk/servlet/gben-server-AssetServer?article=MAIN.UK.TALKTALK.STATIC.HELP.MODEMTYPE&asset=PDF1
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
