Is it possible to get 300 dpi photos out of the olympus stylus 5010 camera?
Yes you can. But 300 dpi is nothing. You could compare this to a question like, fits a yard in a football field.
When talking about 300 dpi, you also must know how big a picture has to be.
According to the manual, your camera can shoot pictures with 4288 by 3216 pixels. When you want to print 300 dpi that is 14 inch by 12 inch pictures. If you want to shoot pictures for smaller results like 6 inch by 4 inch or 7 inch by 5, you can chose a smaller resolution.
Don't be confused by the technical terms of 300 dpi. This is only used in the printing industry. I already printed till 4 times the resolution that was theoretical possible, and still the pictures look very good.
If you have a great picture, shot in the highest resolution, you should be able to make a print of more that 5 or 6 feet and still have a great picture
SOURCE: How do I increase the dpi setting on my Olympus D-425?
Unfortunately most of the Olympus cameras shoot at 72 dpi by default - a suggestion is to shoot at the highest quality setting and then use Adobe Photoshop to modify to 200 dpi if that's what you need.
SOURCE: picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
SOURCE: Need manual for Olympus Stylus 850 sw camera
you can download the manual here http://safemanuals.com/user-guide-instructions-owner-manual/OLYMPUS/STYLUS%20850%20SW-_F Please note that the user guide is in French
SOURCE: Olympus E-300 Digital SLR storing black images.
Most likely the shutter "curtain" (a few pieces looking like sheet metal just behind the mirror, designed to protect the camera CCD from dust and damage due to too much light) is not opening. This will require servicing by Olympus, since you will have to take the camera apart to be able to reach this camera part. Unfortunately, this may be a pretty expensive repair.
SOURCE: Olympus Stylus 300 need date/time stamp to print
On Page 113 of the user manual (see the link below) shows you how to set the menu up to print the date onto the print when printed
Top Menu >Play >Print <up down arrows>Then select No, Date or Time
the user manual is available from here
http://www.olympusamerica.com/cpg_section/cpg_download_manuals.asp
choose your camera from the dropdowns
Direct link to the user manual
http://www.olympusamerica.com/files/oima_cckb/Stylus_300_400_Digital_Mju_300_400_Digital_Reference_Manual_EN.pdf
