FDGFDGD, Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Suspect broken switch on steering column...only temporary solution would be to take electrical connection plug off wiper motor under bonnet until you can fix the switch......
Checked the output supply of the charger using tester, in using tester you must need to know the output supply if it is in dc(direct current) or AC(alternating current), then select it from the selector of the tester if there is a reading then that good,make sure to know the supply of your ryobi charger by checking it from the specs of charger itself.. If the reading is accurate then the charger is good if not then the charger is defective then replace a new one.
Hope this simple solution could help you to solve your problem. Mam/ Sir don't forget me to rate me up I really appreciate what Ratings you have given to me. Thanks a lot and God Bless.
i need a wahl replacement charger PCC as well!!! if anyone knows how to get on let me know because Wahl No Longer sells the clippers so they don't sell the charger now! that sucks wahl !! they should be able to sell you the charger when the charger goes bad like mine did ! it had a short in it and i accidently threw it away!!! now i don't know how to find a replacement charger?thanks
I am not sure if you have the F7222 or F7452 all terran. There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts below follow the link. Please don't forget to give positive feedback.
