Replace the light switch at the top of the door opening. Kill the power to the unit, pull down the grille up top, then remove the cover over the switches. the light switch is the one with the white back. The one with a black back is the fan switch. pull the 2 leads off, open the fridge door, squeeze the switch with a pair of pliers to pop it out of the opening, then install the new switch in the opening facing the same direction. put the wires back on , in any order doesn't matter, put the cover back on the switches, then the grille back on and restore power to the unit.
This, to be honest, is a bigger job than it should be. On the Quest you need to start inside the trunk.
You will need to unscrew the screws on the inside tailgate handle and remove it. Then gently lever around the edges to remove the entire cover panel from the tailgate. This will give you access to the screws (or bolts) holding the narrow outside trim panel that the light is fitted inside. Remove this trim, unscrew the small lens cover for the number plate lights and replace the bulbs.
**Don't Forget to check the bulbs work before you refit the removed trim panels.**
Clean the inside of the lens while it is off to keep the light as bright as possible.
Refit the narrow outside trim. Refit the inside trim panel, pushing the edge clips until they 'click' into place. Refit the inside handle. Close the tailgate and recheck the lights work.
I have a old destiny river hot tub. The lights stopped working suddenly. I can hear a click every time I'm pressing the lights button. That probably means that a relay is clicking so the panel button is working well. But my question is do LEDs are connected in parallel or series? If series if one LED fails all of them will not work (good luck to find the bad one). Anyone have an idea?
I didn't READ any fault in the machine?! It is "just" the Light remains on? Typically, when the dryer ends it's cycle as a safety feature the light will remain in the ON position for a brief period of time. The reason you get no working functions is because the safety feature is disallowing any unauthorized entry in the drum (Kids). The feature usually can be shut off by reading the owners manual. It can not be reset by unplugging the machine! That is the default setting
Hi there, You'll find one fuse box under the bonnet (hood) and another next set on the kick panel inside the cabin....The running lights (Park / marker light also operate the instrument panel lights....The covers of both boxes have directories inside....The one you're interested in is the one inside the cabin.... Regards Johngee10
The fuse panel for the interior lights is located inside the vehicle. The diagram is located on the fuse panel cover . When you pull the cover off you'll see it inside the cover .
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
You probably have a faulty control panel. I've seen a few other problems on FixYa where the control panel didn't work at all. My very own ESD300 had corrosion inside the control panel near the ribbon cable that caused it to stop working. I'm not impressed with Haier's manufacturing controls. In my case it looked like something done to it in manufacturing either allowed water to get inside or caused abnormal deterioration.
