Raymond Weil Tango 5560-STP-00328 Wrist Watch Logo
A
Anonymous Posted on Nov 10, 2013
Raymond weil clasp replacement pin - spring bar
Looking for a replacement pin or spring bar on the clasp of a Raymond Weil 5860 Ladies Tango
2 Related Answers
Anonymous
  • 59 Answers
  • Posted on Aug 28, 2009
SOURCE: I have a rectangular faced Raymond Weil Tango.
is that watch has leather strap or matel,
raymond weil very customized on there watches, some time we order from them parts
and some parts avaliable from out sources as well best answer can be told if we see it, or send me a model number should be on the back of it or picture of it
at
AmFix Jeweley & Watch Repair
203 N. LaSalle St
chicago, IL 60601
312 641 7000
email : [email protected]
www.goamfix.com
Anonymous
  • 6 Answers
  • Posted on Aug 29, 2009
SOURCE: need 2 replacement links for my Raymond Weil 5790
Hi !
Check out the Official Website, the locator for RAYMOND WEIL Retailers (Boutiques + Shops) and ask directly your closest retailer. He'll be able to advise and probably be able to order the good links. He'll give you an estimate too of course.
Hope this helps :)
david
Raymond weil geneve tango 5560 stanless steel 5atm saphire crystal z312161 swiss made\r\nwha can u tell me about that modell? and how much does it worth?
Raymond weil geneve tango 5560 stanless steel 5atm saphire crystal z447644 swiss made can u tell me about that modle? and how much does it worth?
1helpful
How can I remove link pins to adjust metal band from Raymond Weil ladies Tango 527462? One side of the pin has a slot head but a very small screw driver fails to turn the head. The other side has a flat...
Raymond Weil watch braclet has a screw. Twist it, and then push from the other side. You may need to buy a set of basic tool for about 10 dollars from Amazon. Good luck and enjoy your watch. Alan Anderson
How do you get the back off for new batt
Replacing a Raymond Weil watch battery should be performed by an authorized Raymond Weil dealer. Replacing the battery on contemporary Raymond Weils takes some skill because the case is pressurized on some models or contains a rubber gasket to keep it water-tight. If you determine your Raymond Weil watch has a pressurized case back, don't attempt a battery replacement. Take it to an authorized dealer. The warranty on a recently purchased Raymond Weil watch will be voided if you perform a battery replacement yourself. Replacing the battery yourself on older Raymond Weils without a warranty is an acceptable risk.
1helpful
I have a rectangular faced Raymond Weil Tango. Unfortunately it was dropped resulting in the clasp breaking. My question is how much will it cost to repair or replace ?
at
203 N. LaSalle St
chicago, IL 60601
312 641 7000
www.goamfix.com
3helpful
Need 2 replacement links for my Raymond Weil 5790 V 213655 ladies TANGO collection watch
Hi !
Hope this helps :)
david
1helpful
Raymond weil tango watch 4795/1
i'm not sure the references of your watch are correct, but if it is a Quarz movement such as the RAYMOND WEIL Tango Ladies Watch or RAYMOND WEIL Tango Mens Watch you will find the instruction manual about setting and operating the alarm on the Instructions for use page of the official website : Watch Instructions page ( direct link to Watch instructions in pdf ).
Hope this helps :) david
Top Raymond Weil Watches Experts
ADMIN Andrew
ADMIN Andrew
Rogaciani Ogwang
Rogaciani Ogwang
Are you a Raymond Weil Watch Expert? Answer questions, earn points and help others
