Igloo Cooler Igloo - 5.2 Cu. Ft. Chest Freezer - Seashell White Logo
C
Coleman Fowble Posted on Nov 10, 2013
Igloo chest freezer
My igloo 5.2 chest freezer appears to be running normally but there is water coming out of bottom and the items on the floor are thawed. The items near the top remain solidly frozen.
1 Related Answer
mike cooper
  • 884 Answers
  • Posted on Apr 30, 2014
SOURCE: Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
2answers
Do I use distilled water in igloo ice maker
Most ice makers will use ordinary tap water.
Suggest check with Igloo for your model just to make sure.
Nov 02, 2017 • Freezers
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
1helpful
3helpful
2answers
Igloo MIS1530 not cold
If it is out of warranty..... Take it to a football field, and see if you can make three points through the goal posts.... Sorry, wish I had a better solution. They just are too inexpensive to warranty $80/hour work plus parts on them.
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
My igloo fridge makes a buzzing noise is that normal?
I was told the coils probably needs cleaning but I do not see any coils on my igloo freezer. Accepting helpful solutions.
Top Igloo Cooler Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Igloo Cooler Freezer Expert? Answer questions, earn points and help others
