Hi, I have just been using the Henry to clean my car out and some of the carpets were a bit wetter than i appreciated by the footwell. The motor went 'POP' and then stopped working. On Taking the hoover apart water was evidence in the bottom and the top part of the hoover. Is there any way water damage in the motor can be repaired or will i just need ti buy a new hoover? Thanks, Chris
Chris, I hate to be the bearer of bad news, but you've already guessed it. You need a new machine. Personally, if I were you, I'd check into the small shop vac's, type of vacuum. Craftsman has a good one that I've been using for, wow, more years than I can remember now. I had it a long time I know that. I actually picked up a spare one at a garage sale last summer and put it up on a shelf for one my old one finally bites the bullet, but so far, it's still going strong. The wet/dry vac's have a float system in them that actually plug the bottom of the air chamber where the vac draws it's air from, when the water gets too high in the tank. The motor starts to race faster than normal and that's the tipoff that it's full. Dump out the tank and go at it again. Better luck this time.
SOURCE: Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor. Highly likely that you need new carbon brushes. The smell is caused by excessive sparking between the worn brushes and the copper commutator segments. Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed. The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later. When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course). Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag. This is false economy! You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
SOURCE: henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
SOURCE: my hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
SOURCE: My Old Henry hoover is making a VERY loud noise
Most likely the motor bearings have worn out. You can fit a new motor quite easily, but if you need to pay someone else to do it for you the labour plus motor cost will probably make the job uneconomical. Sorry to be the bearer of bad news...
SOURCE: Rewiring a Henry Hoover
no it wont work it wont make any difference , the field coil connections have to be altered , suggest buy a george it has a place to screw the pipe on to blow
