If it is a dishwasher, it sounds like the Flood Sensor is stopping the cycle. There is a tray between the floor and the underside of the basin. If it is a Dishwasher, you just need to find the leak and fix it.
For a Laundry washer, it is a problem with the control board and needs professional diagnosis and repair.
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
tbutts4518 -- Owners Manual is available for download at: http://www.retrevo.com/support/Amana-ADB1500AW-Dishwashers-manual/id/7870ag518/t/2/ If you still need help, please write back. -- SWT
make sure you didnt kink the water hose,wires on tight.check the float inside the dishwasher .it should lift up and down freely if its stuck up (maybe something is under it) it wont let it fill.good luck!
ERIC
Sounds like you need a dishwasher water inlet valve. This part allows water to flow during the wash and rinse cycles. This part is electrical so unplug the appliance before attempting repair. Part cost about $25. It is located behind the bottom kick plate. Two screws and two slip on wire connectors and you are done.
