LG VOYAGER VX10000 Cellular Phone Logo
A
Anonymous Posted on Nov 10, 2013
LG 840G says SIM Lock Code-1 when turned on - LG VOYAGER VX10000 Cellular Phone
Akram Aleryani
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 12, 2018
Akram Aleryani
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2264
Points
5
Redimator
Level 1:
  • Posted on May 26, 2020
Redimator
Contributor
Level 1:
Answers
Questions
0
Helped
2264
Points
Jodi
Level 1:
New Friend:
  • Posted on Apr 05, 2019
Jodi
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2264
Points
Laurie Graham
Level 2:
Sergeant:
  • Expert 307 Answers
  • Posted on Mar 09, 2019
Laurie Graham
Expert
Level 2:
Sergeant:
Answers
307
Questions
0
Helped
187502
Points
581
Contact the mobile carrier
Melinda peyton
Level 1:
New Friend:
Melinda peyton
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2264
Points
UnlockNinja
Level 3:
Master:
  • LG Master 462 Answers
  • Posted on Feb 13, 2019
UnlockNinja
LG Master
Level 3:
Master:
Answers
462
Questions
0
Helped
215736
Points
2283
Here is the SIM unlock code for any LG to use any network SIM
https://www.unlockninja.com/unlock-lg+phone
Boyka LB
Level 1:
New Friend:
  • Posted on Oct 18, 2018
Boyka LB
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2264
Points
1 Related Answer
Anonymous
  • Posted on Sep 03, 2010
SOURCE: I HAVE LG CE0168 PHONE. WHEN I INSERT SIM IN THIS
HOW I CHANGE MY NEW SIM TO ANOTHER SIM BECAUSE I FORGOT MY PIN CODE?
2answers
How to unlock ktf cyon lg kc-3500 In sri lanka
Hard Reset is the only way. If it was asking for a SIM Lock or PUK Lock, that can only come from your cellular provider. They locked it and only they can unlock. Usually reported stolen :>)
How to unlock LG KC3500 ' sim-unlock.net
sim-unlock.net > simlock > LG > KC3500
How to unlock LG KC3500. How to enter an unlock code in a LG KC3500: First option: 1. Insert a sim card from a different network (for example if the device ...
Unlock LG KC3500 Phone ' Unlock Code - UnlockBase
www.unlockbase.com > unlock-phone > lg > kc3500
If your LG KC3500 comes from MetroPCS USA or T-Mobile USA then it's most likely your Cell Phone is locked with "Device Unlock App" and not asking for a ... Missing: ktf ‎cyon
LG Cyon - Wikipedia
en.wikipedia.org > wiki > LG_Cyon
Cyon is LG Electronics' Korean mobile phone brand. LG established the brand in 1997. Like all other mobile phone brands in Korea, they feature the latest ...
1helpful
How unlock my LG 420G to use sim card?
en you receive your email with your unique LG unlocking codes, you may see there's actually more than one code as some models require more than one code to unlock them fully. However, for simplicity, we do aim to send you a single unlock code.
Depending on your modelption 1 method - LG Models
To enter your unlock code, LG phones often require access to a hidden menu first. To access this menu simply enter the digits 2 9 4 5 # * 7 1 0 0 1 #.
1. Insert an original SIM card and turn the phone on
2. Access the hidden menu by typing 2 9 4 5 # * 7 1 0 0 1 #
3. Select 'Menu' and then 'Settings'
4. Next, select 'Security'
5. Select 'Network Provider' and 'Deactivate'
6. Finally enter the Unlocking Code provided. (Please note: Some phones require a slightly different access code - please see the list below if the above access code doesn't work for your phone.)
Option 2 method - LG Models
1. Insert a not accepted SIM Card and switch your LG phone
2. The phone will display 'phone restricted'.
3. Select Cancel
4. The phone will display 'phone restriction code'.
5. Enter the Unlock code provided
6. Select OK
7. Your LG will now be now unlocked
How to unlock a permanently locked lg tracFone 840g
You can unlock by following :
1) switch on phone without sim
2) press 2945#*#
3) then go to factory reset (no.6 in menu) and press Select
mobile will restart then wait 2 minutes for that, after this insert sim and check, same is unblocked.
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Is there an available unlock code for LG 840g tracfone?
To unlock a phone that old the only way would be to call the carrier. For certain phones its free on T mobile, but I dont know about att
13helpful
How to unlock my lg 840g tracfone for free
I have a lg tracfone 840g but its lock, how do I unlock it?
5helpful
5answers
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
