Eliminator MotoMaster Mobile Power Inverter 700w Logo
A
Anonymous Posted on Nov 09, 2013
My 3000 watt inverter says "lup" on the display
Mark Magill
Level 2:
Sergeant:
  • Expert 148 Answers
  • Posted on Jan 27, 2018
Mark Magill
Expert
Level 2:
Sergeant:
Answers
148
Questions
Helped
100775
Points
544
This question is solved in detail on a different page here on Fixya by user Pierre Curtis in detail. It's very well written. Rather than repeat, just click this link:
http://www.fixya.com/support/t26322938-3000_watt_eliminator_olp_lup_codes_any 3000 watt eliminator with OLP and LUP CODES any Ideas
What does lup oup mean on power inverter?
That means that at charge the batteries at displaying12.4 volts, but there is no power behind them, so when you apply a load, the voltage will quickly drop, even faster than the alternator can compensate when the engine is running. The inverter will detect the drop in voltage and throw a code to protect the batteries.
What does opp stand for on a motor master 3000 watt inverter
Unit is shutdown with display showing "OPP"
Inverter is short circuit and has shut down.
Reset to normal operation by using manual switch
1helpful
2answers
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
1helpful
2answers
What does lup mean on inverter?
When readout shows “LUP”, it is indicating a fault happening to the unit. This protects the battery from being over-discharged. Turn off any devices that the inverter is powering. When input voltage rises to 11.7 - 12.3 V DC, inverter restores to normal.
1helpful
On a 1000 watt Duralast inverter what area code is lup
this is a question for a qualified electrician
or ring the store where you bought it from
Why does my 900w microwave trigger the LUP code & alarm?
you need at least a 1900 watt inverter with a fully charged battery to run a 900 watt microwave,it uses 900 watts to make microwaves and it uses 700 or so to run everything else.
6helpful
I have 5000W inverter & hooked up to my battery power supply.display is saying "l up" .i think it means lock up.i was wondering how to unlock.
Could it be L.U.P. it's really L.V.P. but the V looks like a U. If it is it's low voltage protection. If the incoming voltage drops below 10.5 volts, it begins to flash. If the voltage drops below 10 volts it shouts down. If you supply it with 12 v it should restart. If you don't have manual you can view/download one from www.cobra.com.
The low voltage could caused by low battery. Poor connetions. Wire too small for load being supplied.Inverters over 1500 watts will require #1/0 or larger cable, in the shortest possible length. NOTE: Cable size recommendations may vary among inverter brands and models; check the Owner's Manual for the model you purchase before you buy the wire for it.
I need to install my inverter 18 feet from my battery
a very thick one,,,like a baby battery lead on your car,,,its a very bad idear to have it so far away from the battery point, you would be far better off finding a closer place to put it as the volts drop off would have a big drop in out put on the inverter,,,also thats one big mother of a fridge to use 3000 watts????
you need a small power station to run it,,and if it do use 3000 watts your inverter is far to small to do the job, read the out put plate on the inverter,,it says 3000 watts max? not all the time,,,,thats about 2000 watts realy running contently and the whire to feed the inverter will need to carry about 30 amps so your car battery is say 90 amp hours plus the volts drop off, you would be lucky to have the inverter running for 3-4 hours before your battery go's is very flat on you!
7helpful
Power drive 2000 INVERTER what does Lup stand for?
check the wires you either have a bad connection or a bad wire the power in verter has 4 wires 2 neg 2 pos if 1 of the 4 is loose or bad it will give lup code .
3helpful
Power invertor weill beep a few times then shut
insufficient ground...check your connections and try again...do NOT continue to use the unit if the problem persists.
Good Luck
Top Eliminator Electronics - Others Experts
Ngoro
Aron
Steve Pack
Steve Pack
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
