I hooked up my cd player and everything is good, I have double checked everything and No bad connections,no frayed wire, I just Cant get No sound. Power is good, screen and visual is great?
WELL I HAD THE UNIT IN MY CAR BEFORE BUT I TOOK IT OUT FOR A FEW MONTHS AND THEN WHEN I PUT IT BACK IN I HOOKED EVERYTHING UP BUT I COULDNT GET NOT SOUND BUT WHEN I TURNED IT ALL THE WAY UP I JUST DID HEAR THE SOUND BARLEY COMING FROM MY TWEETERS WELL I HAD THE UNIT IN MY CAR BEFORE BUT I TOOK IT OUT FOR A FEW MONTHS AND THEN WHEN I PUT IT BACK IN I HOOKED EVERYTHING UP BUT I COULDNT GET NOT SOUND BUT WHEN I TURNED IT ALL THE WAY UP I JUST DID HEAR THE SOUND BARLEY COMING FROM MY TWEETERS
I have the same problem i turn my volume all the way up and barely hear whats playing it also starts to crackle in the speakers can i get an answer in english I have the same problem i turn my volume all the way up and barely hear whats playing it also starts to crackle in the speakers can i get an answer in english
You can't post conmments that contain an email address.
Checa con una bocina externa las salidas de audio del aparato,si funciona las bocinas del carro son amplificadas.Y si no funciona el amplificador de audio del estereo esta quemado.
Double check your speaker connections. Make sure + goes to plus and - to minus (phase) and make sure all are grounded properly. Is there an amp possibly in line? If so, make sure connections are good there also make sure powered up (it happens to all of us)
Check to make sure your wires are hooked up right. A good way to check your wires is to pull the cd player out. unhook - and + to right rear speaker. Touch the - and + to corresponding ends of a AA battery. Have someone in the trunk to see if the speaker moves. If it doesn't, replace your wire going back or maybe a bad speaker. if it does move and you hook it back to the cd player right, and there is still no sound...it is the cd player. Best of luck to you!
ok maybe i am not understanding what you are trying to do .if you are looking for balance you found it balance is front to back and side to side. if you are saying the volume wont change you might have one rear hooked up to the front and one to the back. this is most common on cars thatare hard wired "no harness"double check the way you ran the wires good luck
check all your fuses and then take the face plate off and push the reset button. if that doesnt work just check the wire connections sometimes if the wires dont have enough contact they want work. i had that issue when i upgraded the speakers in my jeep the connections were not good enough.
are you using RCA outputs(the round red and white plugs)? if you are then your amp is not turning on and if you are hooking up speakers to your RCA's (low level) then you will not hear any audio the signal is to low. would need to know more about how you checked the ic power?? one could verify an output ic by hooking up an amp since the RCA audio signal is picked off just before the output. if the low level works but the speakers do not then you have a bad output. anything else an o-scope would be handy.
good luch stereo tech ([email protected])
