It leaves some water in the bottom and ugly residue as well. Checked drain flapper and hose. All okay.
SOURCE: Water does not drain completely,
If the machine has a auto sensor or auto clean cycle it is supposed to keep water in the bottom. The sensor has to stay wet for it to work properly. My Maytag drains, then fills slightly to do this.
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
SOURCE: Maytag Quiet Series 100 Help - diswasher always
Hi
Thanks for using FixYa.
Dishwasher not draining properly or not draining at all issues can arise due
to different reasons. Usually, these issues are related to kinked hoses,
knocked out disposer unit (if connected with the dishwasher drain hose) &
clogged drain pump & filter.
Also note that dishwashers do not
drain completely after a finished cycle and this is normal. Dishwashers are
designed to leave some water in the unit to ensure that the heating element
doesn’t overheat. If you suddenly begin to experience a large amount of water
being retained in your dishwasher, you have a problem. Some of the most common
reasons include that the drain hose isn’t working properly, the drain pump
isn’t working correctly, or possibly there is a plumbing problem in your home’s
drain lines.
First check whether the drain is
not clogged or blocked and the line is not kinked. Check all the hoses for
blockages & also clean the air gap. Has the disposer been replaced
recently? If so, chances are the knockout is still in place. Simply remove the
drain hose from the disposer, and knock out the plug. If the disposer has not
been replaced, try removing the drain hose from the disposer and use a wet-dry
vacuum (prepared for water, of course) to **** any water (and hopefully anything
else) from the drain line. Then reconnect the hose, and test the unit. If you
have checked the air gap and the drain hose and can’t locate the problem, then
it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
SOURCE: my maytag is about 2 years old, we recently can't
WEll, look for restricted screens on all pump intakes, and look for kinked drain hose. Some water MUST remain in the bottom, but usually not enough to see.
SOURCE: Maytag portable dishwasher is not draining
I have had the same problem and shaking the hose was a
temporary fix. I decided to take apart the dishwasher to see if there was some
kind of a clog. What I found, after taking off the top and back is that the
drain hose gets kinked by the fill hose. They both run up the side of the
machine and back down and are held in place by a cable tie. Over time the drain
hose must have gotten soft and with the fill hose on top of it, it kinks over
the cable tie. Therefore I cut the cable tie, put the drain hose on top of the
fill hose and put on a new cable tie and this seems to have solved the problem
because the water now drains as fast as did when new.
