THANK YOU FOR YOUR E/MAIL JUST WANT TO SAY THE DIGIVOX IS STILL NOT WORKING I CAN GET AROUND 100 STATIONS ALL TO GETHER BUT ALL THE SKY AND SETANTA STATIONS ARE NOW BLOCKED THEY MUST HAVE CHANGED THE CODES IT WENT OFF BEFORE BUT WE WERE ABLE TO GET THE NEW CODES FROM THE INTERNET SOME PERSON SENT THEM IN I HOPE THERE MIGHT BE SOME ONE OUT THERE WHO MIGHT HAVE THE NEW CODES ????? THANKS FOR YOUR HELP / JOHN AMADDUB /
Mine went down last night, it was only after i re-entered the codes on this site under nagrivision that it worked again, appart from Setanta Sports, my feeling is as soon as you rescan as normal it blocks everthing including Rte 2, re enter the Ntl codes under the sub menu 1570.
Try and determine the lowest transponder frequency that you can get a signal on. Look at the frequencies you already have on the channels saved so far and choose the lowest. Then in the installation menu select MANUAL SCAN and set that as the frequency. Make sure you can see a signal and scroll down to Network scan and change to ENABLE with the Right arrow. While still highlighted, click OK. Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? (the ?? being 2 digits).
i've done it myself, thanx. i got up menu, went onto Factory Settings & pressed delete. English language came up & pressed OK,it went back onto menu. then i went onto Installation & made sure it was on NTHELL !!. i then AUTO scanned & saved programmes. i then went back onto menu & pressed 1570 & went onto Nagravision. then making sure it was still on NTHELL, ipressed OK & switched the EMU part, from OFF, back onto ON, i then pressed EXIT 3 times & lo & behold, not only did i have sound, but i could also list the programmes alphabetically !! & i also have SETANTA'S 1,2 & SETANTA SPORTS NEWS !! i really hope all this is helpful & don't forget everyone, MAY THE FORCE BE WITH YOU !! ps. YOU ALSO THEN GET ---- Liverpool tv, Arsenal tv, Celtic tv & Rangers tv. GOOD LUCK EVERYONE & DON'T LET THE BXXXXXDS GRIND YOU DOWN, THERE IS ALWAYS A WAY !!!!! MERRY XMAS 2 U ALL
