Nostalgia Electrics Helman Group CCP-509 Popcorn Maker Logo
A
Anonymous Posted on Nov 10, 2013
Model# RSP100 popcorn - Nostalgia Electrics Helman Group CCP-509 Popcorn Maker
I have a popcorn machine model UE40010 that needs motor complete with gears, light switch and Bulb. Unit has never been used.Was delivered damaged.
Send it back under warranty??
popcorn maker - Nisbets
media.nisbets.com > media > 8oz popcorn manual dist
PDF 8oz COMMERCIAL POPCORN MACHINE. MOdEL NO. & SPECIfICATIONS: Model No.: UE40010. Voltage: AC 230V~50Hz. Input Power: 860W. Please read ...
c72a87b3-8247-4c28-b549-a034aa485c1e.pdf
images.homedepot-static.com > catalog > pdfimages
PDF For Great Northern Popcorn Company Models: 6000 Roosevelt Full ... 4OZ POPPER ASSEMBLY. Model No.: UE40010. Voltage: AC 120V-60Hz. Input Power: ...
Popcorn Machine Parts & Accessories at WebstaurantStore
www.webstaurantstore.com > ... > Popcorn Equipment
Find replacements for your popcorn popper with our popcorn machine parts & accessories! ... Kettle for PMW17R (Digital Display Models). #382pmwkettle. ‎Gold Medal Popcorn Machine ... · ‎Carnival King · ‎Paragon Parts and ...
2answers
Need manual for focus electrics model 82512 popcorn popper
Hello, Tbibbe357 -
Focus Products Group owned the West Bend brand name until late 2016 when The Legacy Companies acquired the West Bend Electrics division.
Therefore, your "Focus Electrics" popcorn popper, model 82512, is also known as the West Bend Stir Crazy Theater-Style popcorn popper.
I found the manual for your machine on the West Bend [company] web site. You can link to the manual here:
https://www.westbend.com/support/user-manuals/popcorn-poppers.html
Choose the link to the for:
82512 - Theater Popper, 2.5 oz.
The manual is in PDF format, so you will need Adobe Reader software (free) to download it, save it to a file in your Documents folder (suggested name for the manual file: Popcorn Popper Manual), and print it for easy reference.
Best wishes.
HOW TO PREPARE POPCORN IN SALTON POPCORN MAKER MODEL PCST22Y
This is the typical measurements for salton poppers
for 3 quarts/litres of popcorn:
1 tbsp. (15 ml) of oil
1/3 cup (85 ml) of popcorn kernels
1 (15 ml)* of butter margerine
1helpful
How much oil, corn and salt do I put in a 2085cl gold medal popcorn machine?
That model is a 6oz popcorn machine.
3/4 cup popcorn kernels (6oz)
slight 1/4 cup oil (1.6oz-a quarter cup is 2 oz.)
1 teaspoon popcorn salt.
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
Oil to popcorn ratio for model 2085?
All popcorn machines use a 3or4:1 corn to oil ratio. More specifically the model 2085 is a 6 oz popper.
6oz. popcorn (3/4 cup)
1.6 - 2oz oil (1/4 cup)
1-2 tsp popcorn salt
1helpful
Salamander RSP100 won't work
AIir lock in pump , pump jammed no power to pump pump in the right way round
Part for Echols popcorn machine
I Have A Echols Popcorn Popper and Would like to know how old it is the serial no. is 86P101
Top Nostalgia Electrics Kitchen Appliances - Others Experts
john h
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
